Real Flight and the Devo 12S
14 Nov 2013 15:24 #15571 by ave1
Real Flight and the Devo 12S was created by ave1
Can someone comment on how to use the Devo 12S as the controller for a flight sim program? Is there a technique or procedure to use the devo 12 a the TX for "Real Flight" flight sim? Has anyone done this?
Thanks for reading and I hope someone might reply, please?
14 Nov 2013 15:42 #15575 by FDR
Replied by FDR on topic Real Flight and the Devo 12S
Simply make a new model with PPM protocol, and use your PPM-USB dongle to connect it to the PC...
  • rbe2012
  • rbe2012's Avatar
14 Nov 2013 19:35 #15585 by rbe2012
Replied by rbe2012 on topic Real Flight and the Devo 12S
Or you can create a new model with USB HID as protocol and connect the tx directly via USB - tested with Windows and good results.
14 Nov 2013 19:40 #15586 by FDR
Yep, but I've never tried that, because the placement of the USB plug is not comfortable on the DEVO 8...
  • rbe2012
  • rbe2012's Avatar
14 Nov 2013 20:59 #15588 by rbe2012
...as it is on Devo12. But works.
15 Nov 2013 10:57 - 15 Nov 2013 10:58 #15600 by Hexperience
Replied by Hexperience on topic Real Flight and the Devo 12S
For real flight you have to connect the trainer port to the real flight controlled. I do it when my daughter flys the blimp and I fly a paintball plane.
Real flight 7 now has a dongle so you don't need to use the interlink as the dongle.
Last edit: 15 Nov 2013 10:58 by Hexperience.
17 Nov 2013 07:11 #15639 by ave1
Replied by ave1 on topic Real Flight and the Devo 12S
Thank you all,,,,, as always and WOW!!! What a difference flying with my devo 12 instead of the TX that came with real flight.
thanks again.
And, would anyone know how the reset button is mapped? Lots of crashes in real life or real flight :)
TY
Time to create page: 0.084 seconds
