Devo 8 --->12
- Birdman
16 Nov 2013 13:54 #15616
by Birdman
Devo 8 --->12 was created by Birdman
Out of curiosity.
The homepage says Devo8 supports 12 channels.
Is it possible to add the missing switches and knobs to Devo8 to make it more or less a Devo 12? (less the big screen)
12 has 2 extra switches, thr hold and trainer. 2 extra knobs, ch6 and 7. These are pots i assume.
Can these be wired up and used with Deviation?
TIA
Bm
TIA
Bm
- Hexperience
16 Nov 2013 15:02 #15618
by Hexperience
Replied by Hexperience on topic Devo 8 --->12
Might as well just buy a 12?
- Birdman
16 Nov 2013 15:15 - 16 Nov 2013 15:17 #15619
by Birdman
Replied by Birdman on topic Devo 8 --->12
4 sliders ????
Last edit: 16 Nov 2013 15:17 by Birdman.
- Birdman
16 Nov 2013 15:16 #15620
by Birdman
Debatable.
I have an 8. 12's aren't exactly cheap.
16 Nov 2013 16:48 #15622
Replied by rbe2012 on topic Devo 8 --->12
No, not really cheap, but with a really good relationship between price and what you get for it.
The 4 sliders are above the sticks on the sides, one (per side) reachable from top and bottom, the other only from bottom. All are pots, also the knobs.
If you want to add hardware, you would have to look if the necessary mcu ports are free. As far as I remember there are not enough free analog inputs which are unused. Adding the switches would be easier since you only need a free standard port and there are some.
The real challenge is soldering. I have added a vibrating motor to my 8s (you will find it in the forum, with some pictures, I believe) and soldered some wires directly to the mcu pins (a little stamp with 25 small pins on each of its four sides with a distance to each other which is ridiculous for standard tools...
- Birdman
16 Nov 2013 17:05 #15623
by Birdman
Soldering is the easy bit for me. I have soldered much smaller than that, it could be done easy enough with a sharp iron and good magnification. Most of all a steady hand.
If i wanted a dedicated TH sw like d12 i don't see anywhere in menu to select it on d8?
Bm
Bm
- Birdman
16 Nov 2013 17:26 #15624
by Birdman
I suspect there might be some programming involved.
That puts it in the "to hard basket" for me.
4:26am
better get some sleep
Bm
4:26am
Bm
16 Nov 2013 18:06 #15625
You won't see it in the D12 either, because we don't have a dedicated TH function (except in the standard GUI)...
www.deviationtx.com/forum/how-to/1950-tu...tle-hold-and-expo-dr
Replied by FDR on topic Devo 8 --->12
Birdman wrote: If i wanted a dedicated TH sw like d12 i don't see anywhere in menu to select it on d8?
16 Nov 2013 19:21 #15626
I have done this before when I added a vibration motor to my Devo8. I had some luck and could use the same port as in Devo10 which has vibration from stock. So I only had to activate the vibration. I have deleted my old repo otherwise I could give you an impression.
Needless to say that such addons will not be included in the main deviation code... (even my wonderful vibration is not
Yes, not too hard because everything you need exists for Devo12 - the trick is to enable the right things. This can mostly be done with editing some header files and you will not have to dive too deep into the code. The only thing is adding the used port and assigning it to the new function. But I could tell you where to search.Birdman wrote: I suspect there might be some programming involved.
- RandMental
16 Nov 2013 20:02 - 16 Nov 2013 20:03 #15628
by RandMental
Replied by RandMental on topic Devo 8 --->12
See this topic for a discussion to add HW related features to the Devo8.
There are already patch files to add a Vibration Motor and two Analogue channels (pots.)
The available, unused I/O in the Devo8 has also been identified, see:
www.deviationtx.com/forum/7-development/...g-aux4-and-aux5#9071
Last edit: 16 Nov 2013 20:03 by RandMental.
- Birdman
16 Nov 2013 23:04 #15632
by Birdman
Thanks guys, much appreciated.
Will look into it.
Bm
Will look into it.
Bm
Time to create page: 0.138 seconds
- Devo 8 --->12
