Mix switch on Devo 10
- kreidler
24 Nov 2013 09:36 - 24 Nov 2013 09:37 #15762
by kreidler
Mix switch on Devo 10 was created by kreidler
I just started to use the mix switch on my Devo 10 without success in the beginning. Now I am wondering if the Walkera QM was out of control or the previous owner changed this switch.
On my Devo the channel monitor displayed the following:
Switch position MIX0:
MIX0 = -100
MIX1 = -100
MIX2 = 100
Which should be the correct assignment for the MIX2 normally.
I just turned the switch in the Tx and now is ok. But can anybody confirm that for MIX0 switch position the channel monitor will display without turning the switch itself:
MIX0 = 100
MIX1 = 100
MIX2 = -100
MIX0 = -100
MIX1 = -100
MIX2 = 100
MIX0 = 100
MIX1 = 100
MIX2 = -100
Last edit: 24 Nov 2013 09:37 by kreidler.
24 Nov 2013 10:56 #15766
Replied by rbe2012 on topic Mix switch on Devo 10
You should see this in the input monitor, not in the channel monitor. The selected switch position is +100%, the others are -100%.
What you see in the channel monitor is the output of the mixers. Look inside to see what is done with the mix switch (inverted or similar is my guess).
- kreidler
24 Nov 2013 12:03 #15771
by kreidler
Replied by kreidler on topic Mix switch on Devo 10
Sorry for being imprecise:
Data given was on the "stick input" page of the channel monitor. Not on the channel output page, of course.
- Mix switch on Devo 10
