MiniCP - Can't bind
28 Nov 2013 20:17 #15995 by Krejzi
MiniCP - Can't bind was created by Krejzi
Hi everyone again.
about half or maybe more year ago I got my MiniCP and Devo7E with +2 switch mod.
It worked without problems, with my Blade Nano and MiniCP.
After I smashed my Mini and Nano, so I gave up for a while with helis.
Now I fixed my MiniCP, but there is a problem I can't bind Mini at all.
On original firmware works without problem, I tried older Deviation firmwares and 3.0 and nothing and actually I have no idea what to do.
Help anyone ? :))
28 Nov 2013 20:34 #15996 by FDR
Replied by FDR on topic MiniCP - Can't bind
If you used auto binding with the stock fw, you should clear the fixed id in deviation on the model setup page.
However if you used fixed id, the same id should work with stock and deviation too...
28 Nov 2013 20:56 #15999 by Krejzi
Replied by Krejzi on topic MiniCP - Can't bind
omg. sorry about that, but I'm pretty sure I had default ID before and it worked, but without ID it works again. Thanks a lot :)
Time to create page: 0.039 seconds
