New 450d01 issues
- Diaz
- Keep flying!
05 Dec 2013 00:21 #16287
by Diaz
Erik
New 450d01 issues was created by Diaz
Hi and hope every one is healthy. I'm hoping some one can help me ... I used the download for the template listed in the deviaion forum on my devo 8s ... It was working fine but now the rudder or tail wants to stay pitched on one side .and I see that I have to much negative pitch at Throtle down how do I change the pitch to my taste in this template ?
has any one experience theses anomalies ? I'm using version 3.0 .one last question can I use GUI on this heli ? In advance thank you for the help ... Erik
Erik
05 Dec 2013 03:48 #16290
Replied by vlad_vy on topic New 450d01 issues
Probaly you need change gyro sense to 0% (50% at other Tx) to swith off heading hold mode, and test rudder again. Then change gyro sense back to switch on heading hold mode.
For other Tx:
Setup value <=50% -> Tail Gyro operates in normal mode (= yaw damping mode)
Setup value >50% -> Tail Gyro operates in AVCS-mode (= heading hold mode)
Setup value = 0% -> maximal effect of normal mode
Setup value = 50% -> minimal effect of normal mode
Setup value = 51% -> minimal effect of AVCS mode
Setup value = 100% -> maximal effect of AVCS mode
Deviation Tx in Advanced mode use -100% to 100% values, not 0% to 100% values.
For other Tx:
- Diaz
- Keep flying!
05 Dec 2013 05:13 #16291
by Diaz
Erik
Replied by Diaz on topic New 450d01 issues
Vlad thank you for the help . It was working fine and when it first bids it works great ,then if I leave it bit at bind it starts to twitch and then it goes off to one side of the shaft .i don't touch the rudder stick at all it starts to twitch . Il try what you stated thank you again your the best .
Erik
Erik
Erik
Time to create page: 0.499 seconds
- New 450d01 issues
