- Devo10, excessive battery drain with pots
- billmester
12 Dec 2013 12:36 - 12 Dec 2013 12:36 #16541
by billmester
Devo10, excessive battery drain with pots was created by billmester
is it just me, or have anyone else noticed that using pots (AUX4 or 5) to drive a channel directly (gyro gain, etc.) drains the TX batteries like hell?
I am using 8xAA NiCd's, 2700mAh. This effect is there constantly, anytime I do that, I see this.
I have set my MIX sw to either give fix 90, 70 and AUX5 to the gyro gain port.
(for testing)
If I switch to the pot, it is draining like 1/100th Volt every second
That effectively nullifies a fully charged battery pack in 2 minutes or so.
As soon as I switch back, the draining stops, sometimes it even crawls back a bit
Before releasing v4, could you please check this?
I am using the August nightly (which was the latest version for a looong time
thanks, bm
(for testing)
thanks, bm
Last edit: 12 Dec 2013 12:36 by billmester.
12 Dec 2013 16:48 #16548
Replied by rbe2012 on topic Devo10, excessive battery drain with pots
Well, I can test it only with my Devo12, but might be different there.
Did you see this big drain with special values of the dials (most left/right) or does it seem to be independent of the position?
- kreidler
12 Dec 2013 19:04 #16557
by kreidler
Replied by kreidler on topic Devo10, excessive battery drain with pots
Could you please post the model.ini for this model. Makes it easier to check
- billmester
12 Dec 2013 19:20 #16559
by billmester
Replied by billmester on topic Devo10, excessive battery drain with pots
I am travelling now - don`t have the tx with me.
I have posted a few ini`s and they have not changed since then... any of them will do, this is general for me.
I`ll check for pot position... the gyro sense is normally at a high (60-90) position.
thanks, bm
thanks, bm
- billmester
12 Dec 2013 19:21 #16560
by billmester
...meaning I can post the ini`s tomorrow
- kreidler
12 Dec 2013 20:30 #16563
by kreidler
I looked into your old posts and found a ini for the HK Rex (attached
From my side no draining when switching to MIX2. Even continuous operation do not drain the batteries. I am using the latest build.
If you have not tested yet I would recommend to change to AUX4 and retest to exclude a damaged pot.
12 Dec 2013 20:53 #16564
Replied by FDR on topic Devo10, excessive battery drain with pots
Is it still that jamming pot you mentioned on rcmodell, or you've already replaced it?
12 Dec 2013 21:25 #16566
I've tested with my Devo12 for more than an hour - same voltage drop if AUX2 is used or switched away (about 0.11V/h). So I believe in general it should not matter if an input is used or not.
If the resistance of your pot is too low it could drain a reasonable amount of current. Normally a current reducing resistor is between the pot's middle pin and the input to avoid damage to the port, but I am not sure if Walkera has spent the money for it...
- billmester
13 Dec 2013 05:14 #16568
by billmester
I have replaced it the same day I got the unit, to the same type.
Later on I put the original back, as I could refurb it.
Let me check for the resistor...
Time to create page: 0.149 seconds
