Devo protocol 11ms mode?
- Hexperience
12 Dec 2013 18:37 #16556
by Hexperience
Devo protocol 11ms mode? was created by Hexperience
The rx802 (and others) support 11ms mode to the servos. Does deviation support this mode and are there any benefits or drawbacks to using it?
I'm looking into using 11ms mode for a flybarless controller. I don't know if it will do anything or not...
cheers
cheers
12 Dec 2013 19:13 #16558
Replied by FDR on topic Devo protocol 11ms mode?
AFAIK the 11/22ms is an rx only feature, it defines the timing against the servos.
The tx sends out the packages much often...
- Hexperience
13 Dec 2013 10:31 #16573
by Hexperience
Replied by Hexperience on topic Devo protocol 11ms mode?
Thanks FDR, so I guess my next question is what is the frame rate of the devo protocol? How often does the TX send the packets to the RX?
Not that my thumbs are faster than 22ms...
13 Dec 2013 12:15 #16574
DEVO protocol sends 4 channel packets every 2.4ms, which means a new 8 channels data in every 4.8ms.
The 11ms rx timing is good for the fast digital servos and for FBL or multirotor controllers...
- Hexperience
13 Dec 2013 13:27 #16576
by Hexperience
Awesome! I'll try it with the mini vbar clone I have and see if there is any difference.
- gmcquet
16 Dec 2013 05:13 #16703
by gmcquet
Replied by gmcquet on topic Devo protocol 11ms mode?
I thought deviation does not support 11ms mode?
I read somewhere that DSM2/dsmx 11ms isn't supported, is that still the case? If so, any plans to change?
What about devo 11ms?
Thanks.
Thanks.
16 Dec 2013 05:18 - 16 Dec 2013 05:23 #16704
Replied by vlad_vy on topic Devo protocol 11ms mode?
For Devo - you only need switch Rx to 11ms mode.
For DSM2/DSMX - at any case you need to have High Speed Rx for 11ms. Right now 11ms mode is not supported.
Last edit: 16 Dec 2013 05:23 by vlad_vy.
- gmcquet
16 Dec 2013 05:33 #16705
by gmcquet
Ok thanks. Will 11ms for dsmx be supported soon?
vlad_vy wrote: For Devo - you only need switch Rx to 11ms mode.
- John-Boy
03 Feb 2014 20:09 #19787
by John-Boy
Replied by John-Boy on topic Devo protocol 11ms mode?
Hi all,
I have quite a few Spektrum rx's to use with a Devo 12S I've ordered. So I'll ask the same question as gmcquet, will Deviation support the 11ms DSMX protocol sometime in the future?
Thanks...!
John L.
Thanks...!
John L.
- Mullson
04 Feb 2014 16:03 - 04 Feb 2014 17:08 #19826
by Mullson
Replied by Mullson on topic Devo protocol 11ms mode?
11 or 22ms has nothing to do with Deviation. Its only a feature that regards the rx to servos. If the rx in question has 11ms mode use it with fast digital servos.
As stated earlier in the tread the tx transmits much faster.
Last edit: 04 Feb 2014 17:08 by Mullson.
04 Feb 2014 16:31 - 04 Feb 2014 16:33 #19827
It's not quite right. DSMX protocol 11ms only applies to servo ports AILE, ELEV, and AUX1 in early radios (thru DX8) and adds RUDD in DX10t and above. The other channels are transmitted at 22ms refresh rates.
And it require 'High Speed' receiver.
Last edit: 04 Feb 2014 16:33 by vlad_vy.
- Hexperience
19 Mar 2014 19:34 #21668
by Hexperience
Old topic I know, but I'm still not clear.
From what I understand of this thread. The ONLY way to get 11ms mode today is to use a devo RX802 in 11ms mode connected to a beastX FBL.
Using an AR7200BX in dsmx mode will not be able to use 11ms mode.
Correct?
Correct?
- HappyHarry
19 Mar 2014 20:31 #21671
by HappyHarry
Replied by HappyHarry on topic Devo protocol 11ms mode?
i don't think deviation has any 11ms dsmx capability bud, no matter what rx is used
- Hexperience
19 Mar 2014 22:53 #21679
by Hexperience
Yeah, I wonder though, is it just a matter of how deviation binds during the dsmx handshake?
If devo protocol is updating all 8 channels in 4.8ms, plus some error checking? Telemetry?... I assume all that could be happening in less than 11ms.
I've been reading too much, and not really getting a lot of good information about latency. ?? I'm getting myself more confused than when I started.
- Thomas.Heiss
27 Sep 2016 10:03 - 27 Sep 2016 10:50 #54324
by Thomas.Heiss
Replied by Thomas.Heiss on topic Devo protocol 11ms mode?
Added DSM high speed option by Vlad:
www.deviationtx.com/forum/protocol-devel...rotocol-errors#54246
Build Deviation 5.0.0 + latest protocols updates + DSMx error fix + high speed: www.deviationtx.com/forum/builds/6407-de...test-protocols#54314
Last edit: 27 Sep 2016 10:50 by Thomas.Heiss.
Time to create page: 0.308 seconds
- Devo protocol 11ms mode?
