Advice please - DSM2 Binding with AR600
- RandMental
22 Dec 2013 11:14 #16921
by RandMental
Advice please - DSM2 Binding with AR600 was created by RandMental
Guys
Advice from the Spektrum/DSM2 users please.
This is the first time I am using the DSM2/DSMX protocol in Deviation.
I bind with an AR600 in DSM2 mode and and it worked as expected.
I did two flights with no problem , except I have to rebind with the Bind plug every time after I switched the TX Off.
I do the binding as in the AR600 Manual: Bind plug in the port, power on, fast flicker, Bind with a 6 Digit code, Led goes solid and I have full control after which I remove the Bind plug and fly.
If I recycle power on the TX, I have to go through the Bind process again, as if the Deviation generates a new binding code after power on.
What am I doing wrong?
Using Devo8s with latest Deviation build from Bitbucket)
22 Dec 2013 11:43 - 22 Dec 2013 12:09 #16922
Replied by vlad_vy on topic Advice please - DSM2 Binding with AR600
Can you try power on Rx several times? Two or three times.
Or change protocol to DSMX.
I have observation that DSMX receivers not always bind from first power on with DSM2 protocol.
Last edit: 22 Dec 2013 12:09 by vlad_vy.
- RandMental
22 Dec 2013 12:33 #16923
by RandMental
Replied by RandMental on topic Advice please - DSM2 Binding with AR600
Thanks Vlad
The AR600 is a DSM2 only receiver, 6 channels. I can get it to bind the first time without a problem, every time.
The receiver "remember" the bind code as it should. If I switch the receiver off and on, it comes up with a slow flicker (brownout Detected) and reconnect to the TX. This I can do many times, with a short off-time and long RX off-time, without losing the bind and reconnection.
BUT - when I switch the TX OFF and ON, and then power the RX, the RX LED stays off and no re-connection occurs.
The Bind code is the same and any changes to the model are saved - TX is on the charger to ensure sufficient voltage for the Models to be saved and reloaded.
To me it seems the Deviation does not "remember" the bind code and/or the two 2.4g channels that were used.
- RandMental
22 Dec 2013 12:40 #16924
by RandMental
Replied by RandMental on topic Advice please - DSM2/X Binding with AR600
Changing to DSMX has only one change - the AR600 don show the brown-out connection but gives a solid LED when re-powered.
However when the TX is powered on and off, same as with DSM2, NO connection and all LEDs off on the RX.
22 Dec 2013 16:25 #16926
I have not any problems with all my DSM2 and DSMX receivers. When I repower Tx they bind over again.
- RandMental
22 Dec 2013 21:26 - 22 Dec 2013 21:26 #16931
by RandMental
I have no idea what is could be the reason for this behaviour, it does the same with an Align 3GX with a Spektrum DSMX sat receiver.
Please let me know what bind code you use and how many channels - lets see if I duplicate your setup. Or even better, please post me one of your DSM2/X models
For now I have replaced the AR600 with a Devo10 and are flying with the original Devention 8s firmware (which works 100% and rebinds immediately so there is no HW issue.) I cannot risk a Deviation problem causing a crash.
Last edit: 22 Dec 2013 21:26 by RandMental.
- kreidler
22 Dec 2013 22:15 #16932
by kreidler
Replied by kreidler on topic Advice please - DSM2 Binding with AR600
I am not sure that might be a stupid question: Do you powered off the Tx also?
I do have Spektrum bricks without bind plug and orangeRx receivers only. But in any case I always do a shutdown after binding. The German manual of the AR600 do have a different translation to the English version: They write to remove the bind plug before power off the Tx (without to mention that the Rx should be powered off also). I use the fixed ID with all Rx without any problems while repowering.
- RandMental
22 Dec 2013 23:38 #16936
by RandMental
I have tried all combinations of power off before and after the Bind plug is removed etc, with no luck.
I have also reloaded the file system to make sure my model.ini files are the latest and had not been corrupted by new firmware releases. I started a new 6 channel Plane model with DSM2 and 6 channels, unfortunately it gives me the same results on both the AR600 DSM2 6ch receiver and a 3GX heli FBL Gyro with a Spektrum sat receiver.
I am out of ideas, will do some more tests tomorrow
- Pattaya01
23 Dec 2013 02:06 - 23 Dec 2013 02:27 #16939
by Pattaya01
Replied by Pattaya01 on topic Advice please - DSM2 Binding with AR600
On some of my models, I also use DSM2, without a problem. After reading your post, I tried this:
AR6100e:
Using default binding code 123456 doesn't work and shows what you described. After I changed it to something else, it did work fine.
AR9000:
Haven tried using the default binding code, but I am using it with another binding code for a while, no problems as you described.
So maybe you are using the default binding code?
AR6100e:
AR9000:
Last edit: 23 Dec 2013 02:27 by Pattaya01.
- RandMental
23 Dec 2013 15:39 #16943
by RandMental
Hi Pat
It is already a concern if certain bind codes don't work without an explanation.
It took the receiver to the LHS this morning where we tested it with a DX4e, it worked perfectly, so I am sure there is no problem with the receiver.
Thus back to Deviation. I have found a bind code that seems to work - will test it over the next day or two.
- Pattaya01
24 Dec 2013 00:19 #16953
by Pattaya01
Fully agree with you. I was also surprised. I will file a bugreport for this.
24 Dec 2013 00:36 #16956
Replied by PhracturedBlue on topic Advice please - DSM2 Binding with AR600
I have no idea how to resolve this.
The modelid is XORed with your transceiver ID, so everyone will get a different result (this means that 2 tx using the same modelid will not interfere)
It also implies that some combination of model ids are illegal, but i have no way to find out what the pattern is.
I've never seen this issue with my Tx, but I only have one official Rx (6200) and the rest are Orange (which probably don't care as much)
- Pattaya01
24 Dec 2013 01:14 #16958
by Pattaya01
As far as I can see, I only noticed it with the default binding code 123456. Could it be that the ASCII code of this string is different? I mean, like characters and not numbers?
I once noticed that on a WiFi access point, using Caps Lock or using the shift key for creating capital letters was not the same. Only when using the shift key, I got connected, using caps lock gave me "wrong access code".
24 Dec 2013 01:16 #16959
No, there is nothing special about the default string.
- Pattaya01
24 Dec 2013 01:21 #16960
by Pattaya01
OK, I ran out of clues. Shall I delete the bug I posted or leave it as it is? I can live with this issue as I never use the default binding code anyway. Maybe a solution would be to make the change of the binding code mandatory.
24 Dec 2013 02:30 #16964
No the bug is definitely real. It needs to stay until we get to the bottom of it.. Unfortunately I just don't know how to fix it right now. We'll add a note about this known issue in the documentation.
- RandMental
28 Dec 2013 08:06 #17256
by RandMental
Problem fixed with commit 81effe3 (Prevent resetting tx.ini ports).
Since this update (27/12/2013) I cannot simulate the problem(s) anymore.
Ticket closed on BitBucket
Time to create page: 0.160 seconds
- Advice please - DSM2 Binding with AR600
