Devo12 emulator
04 Jan 2014 09:25 - 04 Jan 2014 09:26 #17912
Devo12 emulator was created by vlad_vy
PB, is it possible to add to Devo12 emulator possibility to build custom library dfu file?
Last edit: 04 Jan 2014 09:26 by vlad_vy.
04 Jan 2014 15:02 - 04 Jan 2014 15:03 #17922
Replied by rbe2012 on topic Devo12 emulator
I assume you have the emu and want it only to build a new lib. I have described a way here:
http://www.deviationtx.com/forum/custom-skins/2352-high-contrast-wb-skin-thanks-to-fdr#17877
I'll try to improve this (make a standalone lib builder), it is not too high on my list...
Last edit: 04 Jan 2014 15:03 by rbe2012.
04 Jan 2014 15:34 - 04 Jan 2014 15:34 #17927
Replied by PhracturedBlue on topic Devo12 emulator
you mean have the emulator itself build the lib dfu? That isn't very likely.
My long-term goal is to get the Java uploader app finished. then you can drag&drop files to the tx.
In the mean time, I'm woring on writing a little front-end that will make it easy to use.
Last edit: 04 Jan 2014 15:34 by PhracturedBlue.
04 Jan 2014 17:40 #17934
I threw this together. Hopefully it works
www.deviationtx.com/forum/7-development/...-lib-dfu-for-themers
Time to create page: 0.507 seconds
- Devo12 emulator
