Import v4 firmware model to v3 firmware
19 Jan 2014 20:55 - 19 Jan 2014 21:12 #18718 by Tom Z
When I import a v4 model into v3 I then get a message: Ch3 is 0% safe value = -100% or Ch1 is 0% safe value. This message didn't happen in the v4 model so something changed importing it.
The converted v4 ini file still has [safety] Auto=min so I shouldn't get the message. Also flight mode switch is on FMODE0.
What can I do to correct the message?
Here is a v4 model.
name=WalkeraCPHeli
[radio]
protocol=DEVO
num_channels=7
tx_power=100mW
[channel1]
template=expo_dr
[mixer]
src=ELE
dest=Ch1
scalar=50
curvetype=expo
points=30,30
[mixer]
src=ELE
dest=Ch1
switch=ELE DR
scalar=70
curvetype=expo
points=30,30
[channel2]
template=expo_dr
[mixer]
src=AIL
dest=Ch2
scalar=50
curvetype=expo
points=30,30
[mixer]
src=AIL
dest=Ch2
switch=AIL DR
scalar=70
curvetype=expo
points=30,30
[channel3]
safetysw=RUD DR
safetyval=-100
template=expo_dr
[mixer]
src=THR
dest=Ch3
curvetype=7point
points=-100,-66,-33,0,33,66,100
[mixer]
src=THR
dest=Ch3
switch=FMODE1
curvetype=7point
points=100,87,73,60,73,87,100
[mixer]
src=THR
dest=Ch3
switch=FMODE2
curvetype=fixed
[channel4]
template=simple
[mixer]
src=RUD
dest=Ch4
curvetype=expo
points=0,0
[channel6]
template=expo_dr
[mixer]
src=THR
dest=Ch6
scalar=60
usetrim=0
curvetype=7point
points=0,0,0,0,33,66,100
[mixer]
src=THR
dest=Ch6
switch=FMODE1
scalar=60
usetrim=0
curvetype=7point
[mixer]
src=THR
dest=Ch6
switch=FMODE2
scalar=60
usetrim=0
curvetype=7point
[channel7]
template=expo_dr
[mixer]
src=Ch7
dest=Ch7
scalar=64
usetrim=0
curvetype=fixed
[mixer]
src=Ch7
dest=Ch7
switch=FMODE1
scalar=64
usetrim=0
curvetype=fixed
[mixer]
src=Ch7
dest=Ch7
switch=FMODE2
scalar=64
usetrim=0
curvetype=fixed
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer1]
type=countdown
[datalog]
switch=None
rate=1 sec
[safety]
Auto=min
[gui-320x240]
V-trim=129,75,1
H-trim=4,220,3
V-trim=181,75,2
H-trim=191,220,4
Big-box=8,40,Ch1
Small-box=8,95,Timer1
Small-box=8,133,Timer2
Small-box=8,172,Timer3
Bargraph=200,150,Ch1
Bargraph=214,150,Ch2
Bargraph=228,150,Ch3
Bargraph=242,150,Ch4
Bargraph=256,150,Ch5
Bargraph=270,150,Ch6
Bargraph=284,150,Ch7
Bargraph=298,150,Ch8
Toggle=144,36,1,64,128,FMODE
Toggle=144,69,2,65,129,MIX
Toggle=144,102,5,68,0,ELE DR
Toggle=144,135,4,67,0,AIL DR
Toggle=144,168,3,66,0,RUD DR
Toggle=144,201,8,71,0,GEAR
Model=207,40
Here is the same model as above after it has been imported into the v3.
The GUI is gone which is OK I can add it. But now there is a safety message I can't correct.
name=WalkeraCPHeli
[radio]
protocol=DEVO
num_channels=7
tx_power=100mW
[channel1]
template=expo_dr
[mixer]
src=ELE
dest=Ch1
scalar=50
curvetype=expo
points=30,30
[mixer]
src=ELE
dest=Ch1
switch=ELE DR
scalar=70
curvetype=expo
points=30,30
[channel2]
template=expo_dr
[mixer]
src=AIL
dest=Ch2
scalar=50
curvetype=expo
points=30,30
[mixer]
src=AIL
dest=Ch2
switch=AIL DR
scalar=70
curvetype=expo
points=30,30
[channel3]
safetysw=RUD DR1
safetyval=-100
template=expo_dr
[mixer]
src=THR
dest=Ch3
curvetype=7point
[mixer]
src=THR
dest=Ch3
switch=FMODE1
curvetype=7point
[mixer]
src=THR
dest=Ch3
switch=FMODE2
curvetype=fixed
[channel4]
template=simple
[mixer]
src=RUD
dest=Ch4
curvetype=expo
points=0,0
[channel6]
template=expo_dr
[mixer]
src=THR
dest=Ch6
scalar=60
usetrim=0
curvetype=7point
[mixer]
src=THR
dest=Ch6
switch=FMODE1
scalar=60
usetrim=0
curvetype=7point
[mixer]
src=THR
dest=Ch6
switch=FMODE2
scalar=60
usetrim=0
curvetype=7point
[channel7]
template=expo_dr
[mixer]
src=Ch7
dest=Ch7
scalar=64
usetrim=0
curvetype=fixed
[mixer]
src=Ch7
dest=Ch7
switch=FMODE1
scalar=64
usetrim=0
curvetype=fixed
[mixer]
src=Ch7
dest=Ch7
switch=FMODE2
scalar=64
usetrim=0
curvetype=fixed
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer1]
type=countdown
[safety]
Auto=min
Last edit: 19 Jan 2014 21:12 by Tom Z.
19 Jan 2014 21:49 #18723 by PhracturedBlue
Replied by PhracturedBlue on topic Import v4 firmware model to v3 firmware
You cannot import V4 models to V3 (without basically rewriting it). Deviation is backwards compatible (mostly) but not forward compatible. The reason is that switches are handled completely differently in V4 vs V3.
Most likely the fmoode switch isn't applying to the throttle because of the above. What is the situation in which you want touse a V4 model on a V3 Tx anyhow?
19 Jan 2014 22:35 #18725 by Tom Z
Replied by Tom Z on topic Import v4 firmware model to v3 firmware
OK thanks.
People have asked me if my v4 models will work in v3 as they have not upgraded to v4. I told them I would check into this and now I know what to tell people.
I deleted all my v2.1 models posted.
All my new models posted are for v4 only.
Time to create page: 0.030 seconds
