- Deviation software 4.0.1 on devo 8s (Master CP)
- glpdrum
23 Jan 2014 05:19 #18970
by glpdrum
Deviation software 4.0.1 on devo 8s (Master CP) was created by glpdrum
Tom Z
Relating to Master CP settings.
"Model 11-2 has Zero Degree Pitch when throttle hold is on.
If you want control of the swash in TH to help you land in a crash don’t use this model use Model 11 instead".
This setting makes the MCP throttle up!
I must use the -110% setting to make the TH work correctly, Am I missing something?
My TH is set RUDD/DR.
Regards.
Regards.
- Tom Z
23 Jan 2014 05:59 - 23 Jan 2014 07:44 #18974
by Tom Z
Replied by Tom Z on topic Deviation software 4.0.1 on devo 8s (Master CP)
See post below.
Last edit: 23 Jan 2014 07:44 by Tom Z.
- Tom Z
23 Jan 2014 06:38 - 23 Jan 2014 07:42 #18978
by Tom Z
I just checked the model and it works perfect! I download it from this
site (Model 11-2) to make sure the file didn't get corrupted uploading it and it is fine.
I tested in on my Master CP, V120D02S V2, and Mini CP and had no problems at all. I tried it in Normal Mode, Stunt Mode 1, and Stunt Mode 2.
The RUDD/DR switch is both "Throttle Hold" and "Pitch Hold" when you switch it to Position "1" which is up.
Did you hit the right switch "FMOD" thinking it was "Throttle Hold/Pitch Hold"?
If so the heli will go full speed and pitch unless you have the "Throttle Hold" and "Pitch Hold" on (RUDD/DR switch - Position "1").
What setting did you change to -110%?
I would install the model again so you know all the settings are correct.
Last edit: 23 Jan 2014 07:42 by Tom Z.
- glpdrum
23 Jan 2014 18:14 #19000
by glpdrum
Replied by glpdrum on topic Deviation software 4.0.1 on devo 8s (Master CP)
Throttle hold - RUD DR
Thr hold On (in the check box)
Hold position -110 (in the check box)
- Tom Z
23 Jan 2014 19:09 - 23 Jan 2014 20:54 #19005
by Tom Z
I checked and tested the model last night and it works perfect. I tested it in 3 different helicopters: Master CP, V120D02S V2, and Mini CP.
I can't help you as the model works fine for me here and on 3 different helicopters too.
It sounds like you changed my model in the "Mixer GUI" from Advanced to Standard. If so you can't do that. It will reset (erase) my settings that I programmed.
Last edit: 23 Jan 2014 20:54 by Tom Z.
Time to create page: 0.509 seconds
