Linear Throttle and Pitch Curve
- Tom Z
25 Jan 2014 15:07 #19084
by Tom Z
Linear Throttle and Pitch Curve was created by Tom Z
When you make a Throttle or Pitch Curve that is linear 0-25-50-75-100 do you want to assign Multi-points to it? Example: 3, 5, 7, 9 or 13
Or does applying Multi-points only apply if you make a curved Throttle or Pitch Curve?
And if you don't use Multi-points on a linear curve should you use Curve: 1-to-1?
- WheresWaldo
25 Jan 2014 17:43 #19088
by WheresWaldo
Replied by WheresWaldo on topic Linear Throttle and Pitch Curve
Tom,
If you are using linear curves, always remember K.I.S.S. There is no need to clutter up a model with points if you are truly going for linear. Don't forget you can also scale and offset linear without going to the trouble of manually calculating what the middle points should be.
- Tom Z
25 Jan 2014 19:32 #19100
by Tom Z
Replied by Tom Z on topic Linear Throttle and Pitch Curve
What about this?
Normal Pitch curve 7 point.
Stunt 1 & 2 are linear but used 7 points on them also.
Normal mode
-30,-20,-10,0,33,66,100
Stunt 1 & 2
-100,-66,-33,0,33,66,100
Would it also be correct to make Stunt 1 & 2 a Curve: 1-to-1 instead of a 7 point?
Normal mode
Stunt 1 & 2
- linux-user
25 Jan 2014 23:31 - 25 Jan 2014 23:57 #19117
by linux-user
Replied by linux-user on topic Linear Throttle and Pitch Curve
Hi Tom,
as I am new to deviation and even relatively new in the RC hobby I may be false here.
Technicaly you could pick a 1-to-1 curve as well as a 7-point.
I think this depends on the possible "future" of the curve.
If you intend to tweak the curve in the future to something non linear the 7-point curve may be better, if you think it will always be linear, then 1-to-1 is the better choice.
If you change the curvetype you have to enter every value again, as deviation does not calculate your 7-point curve from the values of the existing 1-to-1.
BTW:
I picked one of your models and tweeked the pitch curve to something very nonlinear
BTW:
Last edit: 25 Jan 2014 23:57 by linux-user.
- Tom Z
25 Jan 2014 23:59 #19119
by Tom Z
I like having all three curves 7-point but was wondering if using
1-to-1 instead for the linear curves only was OK or not and it sounds like it is OK. So normal curve would be a 7-point curve and the stunt modes (linear) would be 1-to-1.
It sounds like I can use either method. Either all three modes 7-point or one 7-point and two 1-to-1.
- linux-user
26 Jan 2014 00:08 #19120
by linux-user
Yes, but I personally like it more, all three curves beeing the same type.
Tom Z wrote: Hi,
- Tom Z
26 Jan 2014 00:59 #19122
by Tom Z
Same here. I am going to keep doing it that way, all three curves beeing the same type.
Time to create page: 1.185 seconds
- Linear Throttle and Pitch Curve
