Heli crash with Deviation 3.0.0 on Devo 10
26 Jan 2014 18:18 - 26 Jan 2014 19:57 #19187 by Rollmops67
Heli crash with Deviation 3.0.0 on Devo 10 was created by Rollmops67
I have a Devo 10 with Deviation 3.0.0 installed.
I have allready 2 walkera models programed, and with those I had more than 300 flights without a single Transmitter problem.
2 weeks ago I added a new model, a T-Rex 550.
I did program it from scratch, taking the 6 channels heli template as a basis.
All went well, and the heli flew fine.
Today, at it's eighth flight, suddenly the heli "stopped" mid air, and fell like a brick.
Luckily it was in a field, and these days because of the rain the earth is very wet (>> soft) so the "only" damages are 2 cracked blades, a cracked canopy, and a maybe slightly bent feathering shaft. Well, nevertheless a 140 $ bill... :(
Looking at the transmitter after the crash (I didn't stop it), it showed the message "Ch3 is 55% safe value = - 100%"
That's the safety message showing when you turn on your Tx without the throttle stick fully down.
This means the Tx stopped and started while flying :blink: , waiting me to put the throttle down to start sending to the Rx again.
Throttle failsafe was set to -100, at least I have the consolation this worked... :dry:
Knowing my batteries went charged (9,7 volts at the moment of the incident) there are 2 possibilities :
1) I had a brownout (short loss of power)
2) Deviation crashed and started the Tx again. (reboot ?)
Like said before I have more than 300 flights without problems with the TX so I doubt it was a brownout.
There is a difference in the new model file for the T-rex with the Walkera ones : with the T-Rex the swash mixing is done in the Tx (in the Rx for the Walkeras), therefore I think the Tx has lots more to "calculate".
So my thoughts are it could have been Deviation crashing.
Am I alone with my problem ?
To prevent it to occur again, I deleted the [safety] section in the model.ini file, so the Tx can start even with throttle different than -100.
Not a problem, I always start my Tx with throttle hold and the heli has a soft start
Roland
P.S.
Found an errors.txt file in the Tx, but I don't know if it is from today :
[Hard fault handler00000000
R0 = 40003800
R1 = 00000000
R2 = 20003729
R3 = 00000082
R12 = 01010101
LR [R14] (subroutine call return address) = 0800941d
PC [R15] (program counter) = 080201fe
PSR = 6100002e
BFAR = e000ed38
CFSR = 00000000
HFSR = 00000000
DFSR = 00000000
AFSR = 00000000
SCB_SHCSR = 00000000
impure_ptr = 080213e0
00000026
20000082
0000001a
Last edit: 26 Jan 2014 19:57 by Rollmops67.
26 Jan 2014 20:07 #19206 by FDR
I would definitely upgrade to v4.0.1, it's much more stable, then the v3.0.0 was...
26 Jan 2014 20:12 - 26 Jan 2014 20:18 #19210 by Rollmops67
Replied by Rollmops67 on topic Heli crash with Deviation 3.0.0 on Devo 10
FDR wrote: I would definitely upgrade to v4.0.1, it's much more stable, then the v3.0.0 was...
Yes FDR, think I will do.
I just didn't until today because I was happy with V 3.0.0, but this is less true since today...
Thanks for the answer
Roland
Last edit: 26 Jan 2014 20:18 by Rollmops67.
