Can you force a 'RE-INIT" or "BIND" at startup?
15 Feb 2014 01:00 #20290 by Batch1
Could you confirm that you are using DEVO protocol with your Super CP ?
15 Feb 2014 01:05 #20291 by Batch1
15 Feb 2014 17:13 - 15 Feb 2014 17:15 #20312 by blackmoon
Replied by blackmoon on topic Can you force a 'RE-INIT" or "BIND" at startup?
Yes, I am flying them three with DEVO protocol, I have fixed ID set to none.
Please post your model file so we can compare.
Thanks.
Last edit: 15 Feb 2014 17:15 by blackmoon.
15 Feb 2014 17:33 #20313 by Batch1
THANKS for your help. Now it is working. I did what you said, to look at model config. I load TOM Z standard and it bind with devo protocol, swash react normaly didn't fly it again.
My knowledge in software is very very low. I retired 17 years ago at 53, it was the beginning of instrumentation with CPU
Thanks again
Robert
If you put your model config here I will give it a try
15 Feb 2014 17:48 - 15 Feb 2014 17:53 #20315 by blackmoon
It's the Tom Z one :D
www.deviationtx.com/forum/model-configs/...rs-3d-settings#19194
I just deleted the Fmode2 since devo7e only has Fmode1, adapted expo to my liking, also power reduced to 10mw, no need of 100mw to fly a micro.
Also dual rates are tied to the 3 way switch I added.
Last edit: 15 Feb 2014 17:53 by blackmoon.
15 Feb 2014 18:02 #20316 by Batch1
Didn't look at it again but I will try to adapt it to my liking.
Robert
15 Feb 2014 18:11 #20317 by Batch1
THANKS you for your advice. I load TOM Z model ini and it bind, swash react normaly, will fly it soon
I tough that with the standard gui (like Spektrum...) I can configure it. Didn't know that we have to make a model.ini file.
Thanks again for your help
Robert
15 Feb 2014 18:22 - 15 Feb 2014 18:22 #20319 by blackmoon
This is the model file I'm using (adapted from Tom's one), remember it's for 7E and I made the 1-3way switch mode. The layout is from waldo's config.
File Attachment:
File Name: SuperCP.ini
File Size:4 KB
Last edit: 15 Feb 2014 18:22 by blackmoon.
15 Feb 2014 20:26 - 15 Feb 2014 20:55 #20328 by Batch1
Thanks, I downloaded it, will look at it later. I have a lot of reading to do before I can unsderstand it. (will ask my son if he can help me undestand it or point me where to look to study it, he is a software engineer)
Robert
I start to play with it, I can modify the model.ini from the Tx menu. I understand know why Harry said it will give me something to start with. A lot easier for me. Won't need my son
Last edit: 15 Feb 2014 20:55 by Batch1. Reason: Add comments
18 Feb 2014 01:11 - 18 Feb 2014 01:59 #20488 by Batch1
I should have play with it more before saying that we can adjust the parameter from the TX
Anyway, my Super CP is tune at my liking for know
I am working on the Genius CP with WK2801 protocol and I would like to adjust the gyro sens (gain) before replacing the tail motor. I lost lot of time because I didn't write WK before 2801
Where should I look to adjust the gain ?
Robert
Sorry to ask for it, I have found it in channel7, it is adjusted at 64 and Tom Z says it is equal at 82 in WK world. Will try to play with it but i think my tail motor is gone.
Last edit: 18 Feb 2014 01:59 by Batch1. Reason: Have found it
18 Feb 2014 02:47 #20498 by John-Boy
Hi All,
This topic is getting pretty long and I can't see where the original problem is fixed.
Well, I now have a Devo 12 radio. Finished setup of Deviation 4.0.1 and copied my models over.
I copied my Walkera 4G3 model from the Devo 7e to the Devo 12.
The protocol selected is WK2801, no fixed ID #. When I turn 'on' the Devo 12, the Bind/Re-init screen comes up and binds to the old Walkera 4G3. I would think this is the desired operation.
The Devo 7e does not do this with the 4.0.1 software. I have a single 3 pos switch installed. Is there a build of the software that now works properly?
Thanks to all!
18 Feb 2014 06:29 - 18 Feb 2014 06:30 #20514 by blackmoon
The build on the first post, I am using the one just before and for me it works with the 2401 proto, didn't test with 2801 tough , but I think that Harry did (if I'm not mistaken).
www.deviationtx.com/forum/builds/2661-7e...timer-weekly-updates
The nightlies should work to.
www.deviationtx.com/repository/Deviation...ases/Nightly-Builds/
Last edit: 18 Feb 2014 06:30 by blackmoon.
18 Feb 2014 07:35 - 18 Feb 2014 07:35 #20518 by John-Boy
The 2401 and 2601 both bind on startup for me too..
Please test the 2801 protocol on a Devo 7e, thanks!
Last edit: 18 Feb 2014 07:35 by John-Boy.
18 Feb 2014 12:08 #20520 by blackmoon
If I find my 4G6 I'll give it a shot.
Time to create page: 0.081 seconds
