Solved: Telemetry not working with 4.0.1 for Devo?
02 Feb 2014 18:05 - 03 Feb 2014 21:04 #19704 by mj666
Using a Devo 10 with an "New V120D02S". The optional temperature sensor is attached to the motor. This was always working very well with Deviation 3.0.0. I used this also for low battery warnings. After the upgrade to Deviation 4.0.1 and adjusting the config for the new switch configuration the telemetry is not working anymore. Also the telemetry monitor display shows only empty entries. I also attached the related config files. First is for 4.0.1. Any advice?
Last edit: 03 Feb 2014 21:04 by mj666.
03 Feb 2014 08:02 - 03 Feb 2014 08:06 #19774 by mj666
Replied by mj666 on topic Telemetry not working with 4.0.1 for Devo?
I also analysed an recorded datalog and ist also empty for the telemety data.
BTW: datalog2csv.py is only running on Linux. Don't get it to work with Windows. It's always asking to specify "--bin" even if it is there.
Last edit: 03 Feb 2014 08:06 by mj666.
03 Feb 2014 11:48 - 03 Feb 2014 11:49 #19780 by linux-user
Replied by linux-user on topic Telemetry not working with 4.0.1 for Devo?
I tested your model.ini with my Devo10 (v4.0.1) "New V120D02S" Kombination.
The Voltage is displayed in telemetry monitor.
I don't have a temperature sensor however.
Last edit: 03 Feb 2014 11:49 by linux-user.
03 Feb 2014 21:03 - 03 Feb 2014 21:05 #19797 by mj666
Many thanks for your feedback. After reading your message I got some idea. I recently also upgraded the V120D02S to Firmware v2.0. After downgrading to v1.1 telemetry is working again. This means v2.0 looks to be not supporting telemetry at all. Many thanks for opening my eyes.
Last edit: 03 Feb 2014 21:05 by mj666.
03 Feb 2014 22:16 #19805 by HappyHarry
Replied by HappyHarry on topic Telemetry not working with 4.0.1 for Devo?
iirc the v2 firmware for the v120d02s receiver is to enable use of the futaba compatible satellite receiver
Time to create page: 0.799 seconds
