- Increasing the number of stored models above 100
- John-Boy
18 Feb 2014 02:52 - 18 Feb 2014 02:53 #20501
by John-Boy
Increasing the number of stored models above 100 was created by John-Boy
Hi all,
I wanted to build a library of models in my new Devo 12. I copied model1.ini thru model255.ini with all numbers in-between.
The highest model I can see, at the model select screen, is model100.ini using the Devo 12 software Ver 4.0.1
Is there something I'm missing?
John L.
John L.
Last edit: 18 Feb 2014 02:53 by John-Boy.
18 Feb 2014 03:34 #20504
Replied by PhracturedBlue on topic Increasing the number of stored models above 100
Apparently I coded 100 as the maximum number of models. I guess I figured 'who would ever need more than that on their tx at anytime?'
It is trivial to change this number to up to 255 (I don't think it can be bigger than that) but you're the 1st person to ever hit the current limit.
- John-Boy
18 Feb 2014 04:08 - 18 Feb 2014 04:09 #20508
by John-Boy
Replied by John-Boy on topic Increasing the number of stored models above 100
I was going to setup a library of models above 150, then we could copy down, rename, and use.
Easy for all those around me new to the Deviation software.
And the Devo manual says 255. When you look at the manual, many of the headers are written 'Devo 6/8/10' instead of Devo 6/8/12'.
Thanks...
Thanks...
Last edit: 18 Feb 2014 04:09 by John-Boy.
- Tom Z
18 Feb 2014 06:22 #20513
by Tom Z
I was going to load the 182 V4 models I made into my Devo 10...
Replied by Tom Z on topic Increasing the number of stored models above 100
PhracturedBlue wrote: Apparently I coded 100 as the maximum number of models. I guess I figured 'who would ever need more than that on their tx at anytime?'
- John-Boy
26 Feb 2014 04:58 - 26 Feb 2014 04:59 #20879
by John-Boy
I tried the 'nightly' build in a Devo 8 I'm setting up for a friend.
Still stops at 100 models.
Would a fix to the number of models appear in the nightly builds for the Devo 7e, 8, and 12?
Last edit: 26 Feb 2014 04:59 by John-Boy.
Time to create page: 0.303 seconds
