- Using switches (e.g. trim) to inc / dec channel ?
- enderffx
26 Feb 2014 14:58 #20887
by enderffx
Using switches (e.g. trim) to inc / dec channel ? was created by enderffx
Hi !
This is probably possible, i just cannot find out how:
I would like to "simulate" another analogue input knob.
For this i imagined to use a trim switch up & down to steadily increase the value of an output channel.
So for example Channel 6 starts with 0%, holding a trim up button now increases 10% per second, trim down decreases 10% per second so i could use the trim buttons to go from -100% to +100% (maybe even with the luxury of a translation curve).
Please shoot me if the question is too dumb, but how to do that ?
Greetings,
Ender
P.S. i would use 2 trim switches to adjust camera gimbal horizontal and roll value as he devo 7e has no analogue knobs...
Greetings,
Ender
- jazzjohn
28 Feb 2014 16:07 #20975
by jazzjohn
Replied by jazzjohn on topic Using switches (e.g. trim) to inc / dec channel ?
Since no one else has responded yet, I'll tell you all I know about it:
In the mixer, click on the template button for channel 7 and choose the trim switch as the input. This will enable the trim switch to change the output on the channel.
- enderffx
28 Feb 2014 16:24 #20976
by enderffx
Replied by enderffx on topic Using switches (e.g. trim) to inc / dec channel ?
Hi John !
I have been at that part, but i only managed to assign a static value to switch on or off.
What i like to do is to use the trim buttons to continuously increase or decrease a channel value.
(Well sort of like trimmers usually wok, but allowing the full range of -100% to 100% without adding any other buttons / sticks at a desired channel).
Greetings & thanks,
Ender
Greetings & thanks,
Ender
- IMback!
28 Feb 2014 17:01 #20979
by IMback!
Replied by IMback! on topic Using switches (e.g. trim) to inc / dec channel ?
Just take some channel assign "None" as the input. go to trims set the step to 0.3 and assign the trim you want to the channel
- enderffx
01 Mar 2014 19:00 #21039
by enderffx
Thanks, will do
- jazzjohn
02 Mar 2014 18:19 #21096
by jazzjohn
I was wrong in my previous post since the mixer template doesn't have trim switches as an option.
IMback's method seems to work, but the step size needs to be 1.0 to get the full range of -100% to +100%.
- enderffx
02 Mar 2014 18:22 #21097
by enderffx
Hi !
Haven't tried yet but thanks for the additional infos !
Ender
Ender
02 Mar 2014 19:07 #21099
Replied by PhracturedBlue on topic Using switches (e.g. trim) to inc / dec channel ?
Read section 10.3 in the manual
- enderffx
02 Mar 2014 19:10 #21100
by enderffx
Hello PB.
Actually i did !
IMHO non of the 3 modes did what i need:
Momentary / Toggle / On-Off.
IMBack's solution sounds good, like i said, can not try it right now, will do later.
Greetings,
Ender
Actually i did !
Greetings,
Ender
02 Mar 2014 20:08 #21104
Sorry you are right. I'll add instructions for using it as a virtual channel too. I thought it was in there.
- jazzjohn
02 Mar 2014 23:45 - 02 Mar 2014 23:46 #21116
by jazzjohn
Using IMback's method, I have channel 7 changing up and down properly with the left vertical trim button, but that trim position is not displayed on the home screen along with the three other trims. Its display is stuck at maximum and doesn't move. Any ideas?
File is attached.
File is attached.
Last edit: 02 Mar 2014 23:46 by jazzjohn.
Time to create page: 0.137 seconds
