Using switches (e.g. trim) to inc / dec channel ?
26 Feb 2014 14:58 #20887 by enderffx
Hi !
This is probably possible, i just cannot find out how:
I would like to "simulate" another analogue input knob.
For this i imagined to use a trim switch up & down to steadily increase the value of an output channel.
So for example Channel 6 starts with 0%, holding a trim up button now increases 10% per second, trim down decreases 10% per second so i could use the trim buttons to go from -100% to +100% (maybe even with the luxury of a translation curve).
Please shoot me if the question is too dumb, but how to do that ?
Greetings,
Ender
P.S. i would use 2 trim switches to adjust camera gimbal horizontal and roll value as he devo 7e has no analogue knobs...
28 Feb 2014 16:07 #20975 by jazzjohn
Since no one else has responded yet, I'll tell you all I know about it:
In the mixer, click on the template button for channel 7 and choose the trim switch as the input. This will enable the trim switch to change the output on the channel.
28 Feb 2014 16:24 #20976 by enderffx
Hi John !
I have been at that part, but i only managed to assign a static value to switch on or off.
What i like to do is to use the trim buttons to continuously increase or decrease a channel value.
(Well sort of like trimmers usually wok, but allowing the full range of -100% to 100% without adding any other buttons / sticks at a desired channel).
Greetings & thanks,
Ender
28 Feb 2014 17:01 #20979 by IMback!
Just take some channel assign "None" as the input. go to trims set the step to 0.3 and assign the trim you want to the channel
01 Mar 2014 19:00 #21039 by enderffx
Thanks, will do :-)
02 Mar 2014 18:19 #21096 by jazzjohn
I was wrong in my previous post since the mixer template doesn't have trim switches as an option.
IMback's method seems to work, but the step size needs to be 1.0 to get the full range of -100% to +100%.
02 Mar 2014 18:22 #21097 by enderffx
Hi !
Haven't tried yet but thanks for the additional infos !
Ender
02 Mar 2014 19:07 #21099 by PhracturedBlue
Replied by PhracturedBlue on topic Using switches (e.g. trim) to inc / dec channel ?
Read section 10.3 in the manual
02 Mar 2014 19:10 #21100 by enderffx
Hello PB.
Actually i did !
IMHO non of the 3 modes did what i need:
Momentary / Toggle / On-Off.
IMBack's solution sounds good, like i said, can not try it right now, will do later.
Greetings,
Ender
02 Mar 2014 20:08 #21104 by PhracturedBlue
Sorry you are right. I'll add instructions for using it as a virtual channel too. I thought it was in there.
02 Mar 2014 23:45 - 02 Mar 2014 23:46 #21116 by jazzjohn
Using IMback's method, I have channel 7 changing up and down properly with the left vertical trim button, but that trim position is not displayed on the home screen along with the three other trims. Its display is stuck at maximum and doesn't move. Any ideas?
File is attached.
Last edit: 02 Mar 2014 23:46 by jazzjohn.
Time to create page: 0.623 seconds
