DEVIATION 8s, Lost all models below 8
28 Feb 2014 02:57 #20945 by glpdrum
DEVIATION 8s, Lost all models below 8 was created by glpdrum
Lost all models on radio below 8. All models are shown when opend as a drive :huh:
28 Feb 2014 10:39 #20952 by linux-user
Replied by linux-user on topic DEVIATION 8s, Lost all models below 8
What do you mean with "below 8"? You lost 1-8 or 8-30?
To help you, we would need more details of the incident.
- What was the last thing you did, before you lost the configs?
- did you edit the files with your TX, or with an editor on your PC?
etc.
You know, that the files must be named in consecutive order?
model1.ini
model2.ini
model3.ini
28 Feb 2014 10:45 #20953 by vlad_vy
Replied by vlad_vy on topic DEVIATION 8s, Lost all models below 8
Probably they can have .txt extension (model1.ini.txt)
28 Feb 2014 11:13 #20954 by linux-user
vlad_vy wrote: Probably they can have .txt extension (model1.ini.txt)
The first thing I am doing, when forced to work on a MS-Windows-PC, is uncheck the "hide known extentions" option in explorer :whistle:
28 Feb 2014 14:11 #20964 by WheresWaldo
Replied by WheresWaldo on topic DEVIATION 8s, Lost all models below 8
That would show as an issue if the files are named model1.ini.txt since the .txt would be hidden. If they are model1.ini then they will show as model1, but if they are just named model1 then they show up exactly the same if that folder option is selected.
That is why when I look at general directories on Windows I always use Details instead of any of the other file list options, I can then see the type without seeing the actual extension. Windows will list the type as "Configuration settings".
28 Feb 2014 14:31 #20966 by glpdrum
Replied by glpdrum on topic DEVIATION 8s, Lost all models below 8
Ok where to start??
Started loading a new model, the model showed up on the pc on the drive I named 8s.
The only place it would save the file to is after file 30.
I ejected the drive, turned on the radio and it did not show the file in the menu.
The previous files (models) I have loaded and re named show up in the front of file 1.
Through frustration I tried to replace file 9.
It is gone from the drive when connected to a pc but only that file, 10 and all the rest of the files are shown on the drive.
The radio only shows up to 8.
28 Feb 2014 14:53 #20969 by glpdrum
Correction!
Not in front of file 1.
Here is whats on the radio screen now in the models menu under Cancel-Load to the left of the heli image.
1:MasterCP
2:SuperCP
3:Nano CP X
4:LadyBird
5:SuperCP2
6:MasterCP2
7:Model7
8:Model8
Screen is blank after that.
28 Feb 2014 14:56 - 28 Feb 2014 16:58 #20970 by linux-user
glpdrum wrote: Ok where to start??
you could name the file "model31.ini" and it should be ok.
Did Windows say "it is save to remove the hardware"? It should say something like that!
renamed to what? "model1.ini"?
This should be OK, You can replace any unused "modelxx.ini"
This is what I suspected. "model9.ini" is missing!
Copy a model-file and rename it "model9.ini"
Then all the rest of your models shoud show up again on your TX
Last edit: 28 Feb 2014 16:58 by linux-user.
28 Feb 2014 14:59 #20971 by linux-user
glpdrum wrote: Correction!
1:MasterCP
2:SuperCP
3:Nano CP X
4:LadyBird
5:SuperCP2
6:MasterCP2
7:Model7
8:Model8
Looks good!
Simply add "model9.ini" and all should be fine.
28 Feb 2014 18:29 #20986 by glpdrum
Models file was corrupted. I have replaced it with a new one but radio will still not show the models even though they are in the file on the pc. At this point if I want to load one of TomZ's files I cannot. Doe anyone have a solution?
28 Feb 2014 19:28 - 28 Feb 2014 19:41 #20988 by linux-user
glpdrum,
it is very difficult to guess what you are trying to do.
Please read the following.
deviationtx.com/forum/how-to/1112-how-to...tion-firmware-models
deviationtx.com/forum/how-to/1094-how-to...o-deviation-firmware
And of course:
deviationtx.com/user-manual/Documentation/
Follow the instructions step by step. Be patient and don't hurry.
After each step compare your result with the documentation.
If you get into troubles, try to tell us step by step what you have done.
Please be as specific as possible.
Without knowing in what state your TX is, I would suggest to do a fresh installation of deviation, starting with a new download from deviationtx.com
Last edit: 28 Feb 2014 19:41 by linux-user.
28 Feb 2014 20:06 - 28 Feb 2014 20:08 #20989 by sbstnp
Replied by sbstnp on topic DEVIATION 8s, Lost all models below 8
glpdrum wrote: Models file was corrupted.
How did you determine that?
Files are padded to 4k so what looks like corruption are actually zeros.
Also, afaik model file numbering must not be skipping any position. So if you have model1,2,3,4,5,6,7,8,10 that's bad cause you're missing 9, so 10 and after won't be visible.
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Last edit: 28 Feb 2014 20:08 by sbstnp.
28 Feb 2014 20:26 #20990 by glpdrum
Corrupted file is a supposition.
I put 9 back, looked at all the files in the drive on the pc, safely removed the drive and It still showed only up to 8. Tried one more time making no changes to any files/models, safely removed the drive and the radio shows 1 model now. If I take a new unused models folder they all show up on both pc and radio. If I try to add a model (from a new source i.e. just downloaded) it will not load. If I try and paste a model into a model # it will drop between them, not take their place.
28 Feb 2014 20:34 #20992 by glpdrum
linux-user
Sorry I did not see your post before I responded to ststnp. Your suggestion of restoring the radio and reinstalling is what I've been setting up now. I have removed my old DfuSe tool and installed a new one. I have removed my deviation-devo8-v4.0.1 and downloaded a new one. I trying to think of anything else I can try before I take this step.
28 Feb 2014 20:35 #20993 by stevecox
Replied by stevecox on topic DEVIATION 8s, Lost all models below 8
The actual file name itself is critical see attached for the exact file name format and yours should be named exactly like this, with the exact extension .ini and also watch the line endings in your text editor are set correctly if you edit the files ...
Could you give a screenshot of your directory listing and maybe one or two if the ini files, typically model9.ini
Adelaide
28 Feb 2014 20:39 #20994 by glpdrum
stevecox
I do not know how to do a screen shot?
28 Feb 2014 20:47 #20996 by glpdrum
It will place the screen shot to word but not to this forum?
28 Feb 2014 21:07 - 28 Feb 2014 21:27 #20998 by linux-user
glpdrum wrote: Corrupted file is a supposition.
Ahh, that was helpful.
Now I think I know what you are doing wrong.
Watch the picture from stevecox!
Your models should be named exactly like in the picture.
You can click with the right mouse-botton on a model and rename it to match the naming.
And it may be helpful to display the file extensions
windows.microsoft.com/en-us/windows/show...nsions=windows-vista
Last edit: 28 Feb 2014 21:27 by linux-user.
28 Feb 2014 21:37 #21000 by glpdrum
Going back and making sure all files are.InI did not help. When I go back and run the walkera tool it does not ask me to format the drive.
28 Feb 2014 22:02 - 28 Feb 2014 22:30 #21001 by linux-user
Hmm,
I hope it is not necessary to format the drive.
1.) When you copy the models folder from your fresh deviation download to your TX, then everything is as expected. right?
When you switch your TX to normal operation you see:
1: Model1
2: Model2
9: Model9
10: Model10
2.) now you can pick one of TomZ's models and rename it i.e. "model9.ini"
Do this on your PC, not on the TX. (best before connecting TX to PC) OK?
3.) copy this "model9.ini" to your TX.
now from the view of the PC your models folder should look the same as before (like the picture above from stevecox). right?
4.) you switch your TX to normal operation.
now you should see the new model in your Devo8s
something like
1: Model1
2: Model2
9:MasterCP2
10: Model10
Last edit: 28 Feb 2014 22:30 by linux-user.
Time to create page: 0.161 seconds
