settings info help
- diverich
02 Mar 2014 03:39 #21065
by diverich
settings info help was created by diverich
I have been exploring this firmware and was wondering if when you select a protocol in the model setup page and change the channel to 4. Will this treat the helicopter as a fixed pitch or not and if not then is there a setting that can do this?
02 Mar 2014 19:15 #21101
Replied by rbe2012 on topic settings info help
You have to distinguish between 4-channel-helis (koax and fixed pith (where koax may use even less channels)) and 6-ch-helis (collective pitch).
The second needs the same four channels as the 4-channels does need: throttle, rudder, aileron and elevator. But because the six-ch-helis do not control the height of flying only with the motor speed but with the angle of the blades (blowing more or less air down and up) so for this purpose they need another channel "pitch" (which moved all three servos up and down together to change the blade angle). The sixth channel is mostly used for the rudder gyro control.
So reducing the number of channels does not turn a six-channel-collective-pitch-heli into a 4-ch FP - never. The only way to do this is to let the receiver calculate the additional pitch channel values like it is done when you have an E-Flite Blade mCP-X with a simple 4-channel-transmitter (I had this with my RTF Blade Nano CP-x).
Time to create page: 0.184 seconds
- settings info help
