File error message in DfuSe
- TerryP
07 Mar 2014 04:24 #21325
by TerryP
File error message in DfuSe was created by TerryP
I'm trying to upload deviation on my devo 10 for the first time. I've downloaded 4.01 and pointed to it in DfuSe but it gives me a "this file doesn't have the correct format" error message. What am I doing wrong?
- linux-user
07 Mar 2014 08:03 #21331
by linux-user
Replied by linux-user on topic File error message in DfuSe
Probably your file isn't in dfu format.
Did you read the user manual?
deviationtx.com/user-manual/Documentation/
- TerryP
07 Mar 2014 13:13 #21340
by TerryP
Replied by TerryP on topic File error message in DfuSe
Thank you but, yes, I've read the manual and downloaded the files. I select the file deviation-devo10-v4.0.1.dfu and I get the error message. The transmitter is connected and shows up. I've downloaded the files 3 times to be sure it wasn't corrupted so I'm stumped.
07 Mar 2014 13:49 #21341
Replied by PhracturedBlue on topic File error message in DfuSe
you are using Walera's latest DFuse application? I have never seen it complain about an illegal DFU before.
Can you:
Download this:
www.winmd5.com/
drop the dfu file you are using onto it ( double check the directory is the same as the one you use in the DFU Uploader)
Make sure you get a value of:
0fdaaa91b6371ae59c2e110110eb32f6
Can you:
Download this:
www.winmd5.com/
- TerryP
07 Mar 2014 15:29 #21347
by TerryP
The file would not load into the checksum program so I knew something was wrong. It turns out that, although it looked okay, it was still compressed. (Still fighting with windows 8.1!!!) All is well now. Thank you for your help.
Time to create page: 0.148 seconds
- File error message in DfuSe
