New White Devo 10
15 Jul 2015 01:49 #35453 by vaibhav27
Replied by vaibhav27 on topic New White Devo 10
I already have installed dfuse and the tx file.
When I connect it to the pcand press the ext and turn on, the screen gets stuck at "program update" and doesn't move neither does the pc recognise, it makes the sound that a device was connected but doesn't do anything else.
Plus i looked at the monitor and I see that when i move my throttle stick, the elevator stick also shows a change and the ailerons as well.
Is that a bad tx?
15 Jul 2015 07:15 #35460 by TomPeer
Replied by TomPeer on topic New White Devo 10
You have to press the ENT button while starting up. Not the EXT button.
15 Jul 2015 07:36 #35461 by vaibhav27
That happens i guess when you are on deviation and you have installed it.
If i press the "ent" now, the tx boots up normally.
I am yet to install the deviation software.
16 Jul 2015 01:01 #35503 by vaibhav27
Okay, so i made it through installing the deviation finally!!!
Can anyone provide me with settings for hcp100s with ht8 module please ?
Thank you so much for your help :')
16 Jul 2015 20:07 #35540 by PITCH13
Replied by PITCH13 on topic New White Devo 10
Hello, i just bought a devo 10 and flashed it with deviation, everything seems to work ok but... impossible to load a template, i want to load f 330 450 550 series but impossible, i tried like this:
model menu- model setup- file - load -but i don't see anything, the models have been all charged in the radio, how do i do to upload the file corresponding to F450?
Thanks for responding, i usually manage to get out of such problem but here i'm stuck!!! :(
17 Jul 2015 02:06 #35547 by mwm
Replied by mwm on topic New White Devo 10
Are you looking for the model files from Walkera's firmware? Those don't work on deviation. You can get them back by flashing the original software again, but you'll need new model files to use with deviation.
18 Jul 2015 16:47 #35617 by Thomas.Heiss
Replied by Thomas.Heiss on topic New White Devo 10
You can change between "Load" and "Template" with the right buttons.
Only DeviationTX model.ini and template files are allowed.
You can get them - if provided - in the model sub-forum section.
There is also the folder from the USB file system, which will provide some predefined DeviationTX template files (e.g 6CH heli).
20 Jul 2015 12:28 - 20 Jul 2015 12:29 #35668 by PITCH13
Thanks i got it . ;)
I just mixed templates and models
Last edit: 20 Jul 2015 12:29 by PITCH13.
Time to create page: 0.300 seconds
