RSSI
- TerryP
- TerryP
16 Apr 2014 19:47 #22480
by TerryP
Replied by TerryP on topic RSSI
Thank you. It's not so much the telemetry that I'm asking about. Some receivers can output RSSI to an OSD board so it can be transmitted back to the ground FPV station. (This hobby is as bad as doctors with all the acronyms!
) I don't see anything obvious saying that the Devo Rx's can but some makes can be hacked to do it and I'm wondering if anyone had done this.
- Martian
22 Apr 2014 02:47 #22648
by Martian
HELIs: V929, MCX2, MSR, Nano CP X
TX: Devo 10 (Deviation 3.0.0)
Replied by Martian on topic RSSI
I too would be interested in knowing if there is an RX that is compatible with Deviation that can output RSSI. Thinking about building an FPV quad and would be nice to equip it with a receiver that could pass that data to an OSD.
- Pattaya01
25 Apr 2014 01:36 #22707
by Pattaya01
Replied by Pattaya01 on topic RSSI
I have also been trying to find info on getting the RSSI out of Devo receivers. RCGroups has some thread on how to get the RSSI voltage out of the receivers, but unfortunately not for Devo.
Mostly, some pin on the MCU has the RSSI voltage and it would be easy to solder a wire to somewhere to get this voltage out of the RX to use it on an OSD or APM.
Anybody has any idea where to get this signal on any of the Devo receivers?
Time to create page: 0.418 seconds
