RSSI
16 Apr 2014 15:45 #22468 by TerryP
RSSI was created by TerryP
Is it possible to get RSSI out of the 1002 or 1202 RX?
16 Apr 2014 17:25 #22472 by PhracturedBlue
Replied by PhracturedBlue on topic RSSI
No. Walkera does not report RSSI via telemetry.
16 Apr 2014 19:47 #22480 by TerryP
Replied by TerryP on topic RSSI
Thank you. It's not so much the telemetry that I'm asking about. Some receivers can output RSSI to an OSD board so it can be transmitted back to the ground FPV station. (This hobby is as bad as doctors with all the acronyms! :) ) I don't see anything obvious saying that the Devo Rx's can but some makes can be hacked to do it and I'm wondering if anyone had done this.
22 Apr 2014 02:47 #22648 by Martian
Replied by Martian on topic RSSI
I too would be interested in knowing if there is an RX that is compatible with Deviation that can output RSSI. Thinking about building an FPV quad and would be nice to equip it with a receiver that could pass that data to an OSD.
HELIs: V929, MCX2, MSR, Nano CP X
TX: Devo 10 (Deviation 3.0.0)
25 Apr 2014 01:36 #22707 by Pattaya01
Replied by Pattaya01 on topic RSSI
I have also been trying to find info on getting the RSSI out of Devo receivers. RCGroups has some thread on how to get the RSSI voltage out of the receivers, but unfortunately not for Devo.
Mostly, some pin on the MCU has the RSSI voltage and it would be easy to solder a wire to somewhere to get this voltage out of the RX to use it on an OSD or APM.
Anybody has any idea where to get this signal on any of the Devo receivers?
26 Apr 2014 14:12 #22730 by PhracturedBlue
The CYRF6936 doesn't output RSSI except via a query. It will not be possible to get RSSI from a DECO rx without reprogramming the Rx
