solved: Naza M-V2 with Gimbal (H32D) Devo10 Config
19 Apr 2014 11:08 - 19 Apr 2014 20:39 #22568 by mahandel
Hello all - I need your help :woohoo: please!!
I am complete new to deviation and have a F550 with Naza M V2, I used Bullfrogs model8.ini config:
it worked perfectly until I installed the Zenmuse Gimbal... :dry:
what did I do:
Gimbal connected to Naza, GoPro installed and it "works" now (even if I don't know why?!)
First it always pointed to the ground, then I messed up the config by trying to assign AUX4 or 5 to the tilt function.
I loaded the original config (from Bullfrog) and recalibrated the sticks and now I have:
1. Gimbal working, but tilt function is on FMOD switch!
2. GPS mode cannot be used anymore: MIX switch jumps from "Control switch Mode" position too-far-left to too-far-right, only in center it points to "atti."
3. IOC does not work anymore - X2 seems not to be configured :blink:
HELP - I think I messed it up and don't know how to fix this!!!
PLEASE explain to a complete newbee how to change the settings:
1. Gimbal tilt should be set to AUX 4 or 5
2. GPS / atti (/ manual) to be set to FMOD
3. IOC set to MIX
THANK YOU VERY VERY MUCH!!!!
[Devo-10 @ DJI Flamewheel F550 with GoPro3+]
Last edit: 19 Apr 2014 20:39 by mahandel.
19 Apr 2014 20:36 - 19 Apr 2014 20:41 #22582 by mahandel
thanks to Bullfrog and several experiments I finally got it working!!
(hint: don't forget to recalibrate AND turn the 2 AUX knobs!! not only the sticks)
the gimbal can now be controlled by AUX5 knob set to channel 8
connected at: Naza-X1 -> AUX3-RX1002
I would be glad to hear if someone uses the model.ini :P
greets
mahandel
(F550, Germany)
Last edit: 19 Apr 2014 20:41 by mahandel.
23 May 2014 07:57 #23515 by mahandel
I'm flying quite a while now with the current .ini and completely satisfied!
Layout:
- got me a quadcopter icon (from the forum - thanks :P if anyone has a handy hexacopter icon I would love to have it)
- gimbal tilt rate shown on the display (very useful!)
- 2 timers: countdown + timer
hope someone can use it and leaves his comment :woohoo:
greetings from Germany
falls es jemand lieber auf deutsch liest:
die model.ini nutze ich jetzt schon eine ganze Weile und bin vollauf zufrieden damit!
Layout:
- im Forum nur ein Quadcopter Icon gefunden - wer ein Hexacopter icon hat: her damit :kiss:
- Gimbalstellung in % wird angezeit - seeehr nuetzlich! (vor allem wenn man die Kamera nicht mehr erkennt vom Boden aus)
- 2 Timer: Stoppuhr und Countdown
Ich wuerde mich freuen wenn jemand die ini benutzt und sich meldet wenn alles klappt!
viele Flieger-Gruesse
Time to create page: 0.299 seconds
