- solved: Naza M-V2 with Gimbal (H32D) Devo10 Config
- mahandel
19 Apr 2014 11:08 - 19 Apr 2014 20:39 #22568
by mahandel
[Devo-10 @ DJI Flamewheel F550 with GoPro3+]
solved: Naza M-V2 with Gimbal (H32D) Devo10 Config was created by mahandel
Hello all - I need your help
please!!
I am complete new to deviation and have a F550 with Naza M V2, I used Bullfrogs model8.ini config:
it worked perfectly until I installed the Zenmuse Gimbal...
what did I do:
Gimbal connected to Naza, GoPro installed and it "works" now (even if I don't know why?!)
First it always pointed to the ground, then I messed up the config by trying to assign AUX4 or 5 to the tilt function.
I loaded the original config (from Bullfrog) and recalibrated the sticks and now I have:
1. Gimbal working, but tilt function is on FMOD switch!
2. GPS mode cannot be used anymore: MIX switch jumps from "Control switch Mode" position too-far-left to too-far-right, only in center it points to "atti."
3. IOC does not work anymore - X2 seems not to be configured
HELP - I think I messed it up and don't know how to fix this!!!
PLEASE explain to a complete newbee how to change the settings:
1. Gimbal tilt should be set to AUX 4 or 5
2. GPS / atti (/ manual) to be set to FMOD
3. IOC set to MIX
THANK YOU VERY VERY MUCH!!!!
what did I do:
3. IOC set to MIX
Last edit: 19 Apr 2014 20:39 by mahandel.
- mahandel
19 Apr 2014 20:36 - 19 Apr 2014 20:41 #22582
by mahandel
Replied by mahandel on topic HELP: Naza M-V2 with Gimbal (H32D) Devo10 Config
thanks to Bullfrog and several experiments I finally got it working!!
(hint: don't forget to recalibrate AND turn the 2 AUX knobs!! not only the sticks)
the gimbal can now be controlled by AUX5 knob set to channel 8
connected at: Naza-X1 -> AUX3-RX1002
I would be glad to hear if someone uses the model.ini
greets
mahandel
(F550, Germany)
greets
mahandel
(F550, Germany)
Last edit: 19 Apr 2014 20:41 by mahandel.
- mahandel
23 May 2014 07:57 #23515
by mahandel
Replied by mahandel on topic F550: Naza M-V2 with Gimbal (H32D) Devo10 Config
I'm flying quite a while now with the current .ini and completely satisfied!
Layout:
- got me a quadcopter icon (from the forum - thanks
if anyone has a handy hexacopter icon I would love to have it)
- gimbal tilt rate shown on the display (very useful!)
- 2 timers: countdown + timer
hope someone can use it and leaves his comment
greetings from Germany
falls es jemand lieber auf deutsch liest:
die model.ini nutze ich jetzt schon eine ganze Weile und bin vollauf zufrieden damit!
Layout:
- im Forum nur ein Quadcopter Icon gefunden - wer ein Hexacopter icon hat: her damit
- Gimbalstellung in % wird angezeit - seeehr nuetzlich! (vor allem wenn man die Kamera nicht mehr erkennt vom Boden aus)
- 2 Timer: Stoppuhr und Countdown
Ich wuerde mich freuen wenn jemand die ini benutzt und sich meldet wenn alles klappt!
viele Flieger-Gruesse
Layout:
Layout:
Time to create page: 0.385 seconds
