help with new update 4.0.1
- royalstar05
21 Apr 2014 13:53 - 21 Apr 2014 15:47 #22629
by royalstar05
help with new update 4.0.1 was created by royalstar05
I have the Devo 10 that I am going to put the update on my question is will I lose all my plane settings that are stored now and more importent is I have a Walkera wk-2402 and in the discription of the update it say it will support wk-2401 I cannot find that transmmitter is that a misprint or are they the same
Thanks for the help
Thanks for the help
Last edit: 21 Apr 2014 15:47 by royalstar05.
- Hondawasaki
22 Apr 2014 01:30 #22646
by Hondawasaki
Replied by Hondawasaki on topic help with new update 4.0.1
make a new folder on your desktop and copy paste all the contents of the tx in there. before you update .... then if things go wrong you can simply copy paste them back into the tx along with version 4.0 ...also after updating you can re import all the models model icons and stuff
23 Apr 2014 20:40 #22674
Replied by FDR on topic help with new update 4.0.1
If you currently use the original fw, then while you won't "loose" those settings, you can't use them in deviation.
However if you later install back the stock fw, your old models will be there...
The WK2401 and 2402 protocols are the same, these are actually tx types, which use the same protocol...
Time to create page: 0.067 seconds
- help with new update 4.0.1
