Deviation software errors txt
- FireAngel
25 Apr 2014 17:41 #22719
by FireAngel
Deviation software errors txt was created by FireAngel
Hi, I'm trying to pin down a fault, I'm not sure if it's a software or hardware problem.
I've lost control of my quads throttle twice this week where it just accelerates for 5 or 6 seconds at maximum throttle then shuts down. Reducing the throttle or using the kill switch has no effect.
Can some one please tell me what this error.txt message means,
[Soft fault]
devo10-v4.0.1
R0 = 40013000
R1 = 00000000
R2 = 2000bf2c
R3 = 00000002
R12 = 00000006
LR [R14] (subroutine call return address) = 080073e1
PC [R15] (program counter) = 080250f0
PSR = 61000000
BFAR = e000ed38
CFSR = 00000000
HFSR = 00000000
DFSR = 00000000
AFSR = 00000000
SCB_SHCSR = 00000000
Top of Stack:2000c000
Stack Detect:2000bee8
Backtrace:
2000befc : 080073e1
2000bf0c : 080073c5
2000bf14 : 08006b89
2000bf24 : 08006339
2000bf44 : 080069a3
2000bf54 : 08007867
2000bf64 : 0800db8b
2000bf7c : 0800dc09
2000bf84 : 08005709
2000bf95 : 080500db
2000bfbc : 0800dde7
2000bfcc : 0800de17
2000bfdc : 0800e8bd
2000bfe4 : 0800eba1
2000bfe5 : 080800eb
2000bff4 : 0800afaf
Done
Devo10 v4.0.1 + a7105/NRF24L01
Walkera HotenX Quad
[Soft fault]
devo10-v4.0.1
R0 = 40013000
R1 = 00000000
R2 = 2000bf2c
R3 = 00000002
R12 = 00000006
PSR = 61000000
BFAR = e000ed38
CFSR = 00000000
HFSR = 00000000
DFSR = 00000000
AFSR = 00000000
Backtrace:
2000befc : 080073e1
2000bf0c : 080073c5
2000bf14 : 08006b89
2000bf24 : 08006339
2000bf44 : 080069a3
2000bf54 : 08007867
2000bf64 : 0800db8b
2000bf7c : 0800dc09
2000bf84 : 08005709
2000bf95 : 080500db
2000bfbc : 0800dde7
2000bfcc : 0800de17
2000bfdc : 0800e8bd
2000bfe4 : 0800eba1
2000bfe5 : 080800eb
2000bff4 : 0800afaf
Done
Walkera HotenX Quad
26 Apr 2014 14:24 #22731
Replied by PhracturedBlue on topic Deviation software errors txt
It appears to have crashed while reading font info from the flash drive. The errors.txt would only be generated on a Tx reset, so it should be obvious when it was generated. You didn't mention that though, so the crash may be entirely unrelated.
- FireAngel
26 Apr 2014 19:47 #22740
by FireAngel
Replied by FireAngel on topic Deviation software errors txt
Hi PhracturedBlue thanks for the reply.
I did not notice a Tx reset either time.
Is the "crash while reading font info from the flash drive" something I would have likely caused ?
To try and simulate a reset I have just tried turning off the Tx power while the quad was at half throttle(secured) and it just powered down.
As this is a intermittent fault I am now flying with both a modded and stock transmitter, if it happens again while using the stock Tx at least i'll know the fault is with the quad.
- FireAngel
14 May 2014 19:24 - 14 May 2014 19:26 #23233
by FireAngel
Last edit: 14 May 2014 19:26 by FireAngel.
14 May 2014 21:19 #23238
Does that go away when you reboot or not?
It definitely looks like some sort of font corruption, but I have never seen that with 4.0.1.
One thing you should do is to open errors.txt in a text editor and delete all lines then save it (don't delete the file). Then if Deviation crashes, it will fill in the errors.txt and you'll have a better idea when it happened.
Are you using Deviation in English?
- FireAngel
14 May 2014 22:08 #23240
by FireAngel
Hi PB,
Since the last occurrence a few weeks ago I've had 40+ flights without a problem.
I used Notepad++ to delete all lines, there was nothing wrote in the error file this time.
Yes,I am using Deviation in English.
When I power off/On it reverts back to normal and works fine.
Time to create page: 0.617 seconds
- Deviation software errors txt
