Deviation software errors txt
25 Apr 2014 17:41 #22719 by FireAngel
Deviation software errors txt was created by FireAngel
Hi, I'm trying to pin down a fault, I'm not sure if it's a software or hardware problem.
I've lost control of my quads throttle twice this week where it just accelerates for 5 or 6 seconds at maximum throttle then shuts down. Reducing the throttle or using the kill switch has no effect.
Can some one please tell me what this error.txt message means,
[Soft fault]
devo10-v4.0.1
R0 = 40013000
R1 = 00000000
R2 = 2000bf2c
R3 = 00000002
R12 = 00000006
LR [R14] (subroutine call return address) = 080073e1
PC [R15] (program counter) = 080250f0
PSR = 61000000
BFAR = e000ed38
CFSR = 00000000
HFSR = 00000000
DFSR = 00000000
AFSR = 00000000
SCB_SHCSR = 00000000
Top of Stack:2000c000
Stack Detect:2000bee8
Backtrace:
2000befc : 080073e1
2000bf0c : 080073c5
2000bf14 : 08006b89
2000bf24 : 08006339
2000bf44 : 080069a3
2000bf54 : 08007867
2000bf64 : 0800db8b
2000bf7c : 0800dc09
2000bf84 : 08005709
2000bf95 : 080500db
2000bfbc : 0800dde7
2000bfcc : 0800de17
2000bfdc : 0800e8bd
2000bfe4 : 0800eba1
2000bfe5 : 080800eb
2000bff4 : 0800afaf
Done
Devo10 v4.0.1 + a7105/NRF24L01
Walkera HotenX Quad
26 Apr 2014 14:24 #22731 by PhracturedBlue
Replied by PhracturedBlue on topic Deviation software errors txt
It appears to have crashed while reading font info from the flash drive. The errors.txt would only be generated on a Tx reset, so it should be obvious when it was generated. You didn't mention that though, so the crash may be entirely unrelated.
26 Apr 2014 19:47 #22740 by FireAngel
Replied by FireAngel on topic Deviation software errors txt
Hi PhracturedBlue thanks for the reply.
I did not notice a Tx reset either time.
Is the "crash while reading font info from the flash drive" something I would have likely caused ?
To try and simulate a reset I have just tried turning off the Tx power while the quad was at half throttle(secured) and it just powered down.
As this is a intermittent fault I am now flying with both a modded and stock transmitter, if it happens again while using the stock Tx at least i'll know the fault is with the quad.
14 May 2014 19:24 - 14 May 2014 19:26 #23233 by FireAngel
Had a problem again today, quickly looked at the screen to see if it was rebooting but could not tell.
Took this picture of the screen.
Can you think what could be causing this or what I could try to fix it ??
Last edit: 14 May 2014 19:26 by FireAngel.
14 May 2014 21:19 #23238 by PhracturedBlue
Does that go away when you reboot or not?
It definitely looks like some sort of font corruption, but I have never seen that with 4.0.1.
One thing you should do is to open errors.txt in a text editor and delete all lines then save it (don't delete the file). Then if Deviation crashes, it will fill in the errors.txt and you'll have a better idea when it happened.
Are you using Deviation in English?
14 May 2014 22:08 #23240 by FireAngel
Hi PB,
Since the last occurrence a few weeks ago I've had 40+ flights without a problem.
I used Notepad++ to delete all lines, there was nothing wrote in the error file this time.
Yes,I am using Deviation in English.
When I power off/On it reverts back to normal and works fine.
Time to create page: 0.125 seconds
