Devo 12s + RX1202 can't bind with Naza
28 Apr 2014 16:50 #22772 by billcwc
Hello!
I got a second Devo 12s w/RX1202 and try to connect with DJI Naza. But I don't know why the can't RX1202 can't connect with Naza.
Wired like this:
RX1202 <-> NAZA
ELEV <-> E
AILE <-> A
THRO <-> T
RUDD <-> R
GEAR <-> U
AUX1 <-> X1
AUX2 <-> X2
AUX4 <-> Gamble Pit
AUX5 <-> Gamble Roll
Ref from : www.deviationtx.com/forum/model-configs/1885-dji-phantom#10908
But the naza assistant can't detect RX1202.
Any body can't bind with Naza?
Thank you so much
  • Maxpower50
  • Maxpower50's Avatar
  • Newer Tell some you dont now
07 May 2014 13:05 #22971 by Maxpower50
Replied by Maxpower50 on topic Devo 12s + RX1202 can't bind with Naza
To use this Devo10 Tx setup, the connections between Receiver and Naza
example how your radio its set up
Naza Rx Channels Tx Switches/Sticks
A Aileron AILE stick
E Elevator ELEV stick
T Throttle THRO stick
R Rudder RUDD stick
U FLAP (AUX1) Mix Switch
X2 GEAR FMD Switch
X1 AUX2 AUX2 Switch
Model 1: (for normal flying)
System -> STMOD = MODE2
Model -> TYPE = AERO
Model -> INPUT -> FM SW = FMD (FMD switch is used as FMD); FMTRM = COMM; HLDSW = HOLD (HOLD switch is used as Throttle Hold)
Model -> OUTPuT -> GEAR = FMD, ACT (for FMD switch output to GEAR channel); FLAP = MIX, ACT (for MIX switch output to FLAP/AUX1 channel); AUX2 = AUX2, ACT (AUX2 know output to AUX2 channel)
Model -> WING = NORM, VTAIL = INH
Model -> AMPLI = +20 (highest power)
Model -> FIXID (see Devo7 manual on how to fix ID)
Function -> REVSW -> ELEV = NORM; AILE = NORM; THRO = NORM; RUDD = NORM; GEAR = REV; FLAP = REV; AUX2 = NORM
Function -> TRVAD -> ELEV = U 100%, D 100%; AILE = L 100.0%, R 100.0%; THRO = H 100.0%, L 100.0%; RUDD = L 100.0%, R 100.0%; GEAR = +88.0%, - 99.0%; FLAP = U 40.5%, D 83.5%; AUX2 = +46.5%, -66.5%
Note: The Gear and Flap is critical to set to %above or otherwise your MIX and FMD switch will not trigger the control mode and IOC mode appropriately. The AUX2 travel adjustment is for adjust the travel rage of Gimbal pitch control (set the way you like).
Function -> SUBTR -> ELEV = 0.0%; AILE = 0.0%; THRO 0.0%; RUDD 0.0%; GEAR 0.0%; FLAP D 6.0%, AUX2 0.0%
Function -> DREXP -> leave as default value. Do not set D/R exponential.
Function -> THHLD -> STATE = ACT; POSIT = +50.0% (for Throttle Hold setup)
Function -> THCRV -> leave as default
Function -> SAFE -> ELEV = SAFE, 0%; AILE = SAFE, 0%; THRO = SAFE, H 3%; RUDD = SAFE 0%; GEAR = HOLD; FLAP = SAFE, D 34%; AUX2 = HOLD
The rest of parameters just leave them as default
Time to create page: 0.190 seconds
