Simulators pt.2
- Worldofshiva
07 May 2014 13:38 #22972
by Worldofshiva
pls i didnt understand what i need to do to connect my devo7e to a simulator...okay i have the usb cable and all... i just wish to know how should i configure the Tx(settings USBHID-PPM etc.) couse im a totaly newbie.
and last but not least i wish to know any FREE simulator that i can use with deviation either for mac os or windows thanks
Shiva
As i say greetings from India lol
Simulators pt.2 was created by Worldofshiva
Shiva
07 May 2014 13:52 #22973
Replied by PhracturedBlue on topic Simulators pt.2
You can try:
rcflightsim.com/
I have verified that it works with Deviation, and there is a free version.
There is also:
rcdeskpilot.com
Though I have no experience withit.
I use Phoenix myself, but it is not free to use.
You haven't said what you are looking for. The easiest thing to do is to:
1) Go to the model page
2) Press 'Up' to get to the 'Mixer Gui' and change it to 'Standard'
4) back on the model page, scroll down to Protocols (probably set as 'DEVO', and change it to 'USBHID'
5) Press 'Re-Init'
your controller should now act as a 6-channel joystick. You may want to properly configure dual-rates, throttle-hold, curves, etc, but it should get you going. you will need to learn to program the transmitter, and the best wayto do that is to read the manual.
rcflightsim.com/
There is also:
rcdeskpilot.com
5) Press 'Re-Init'
Time to create page: 0.970 seconds
- Simulators pt.2
