PPM
- Pattaya01
- Pattaya01
- Pattaya01
- Pattaya01
31 May 2014 11:15 - 31 May 2014 11:18 #23780
by Pattaya01
Replied by Pattaya01 on topic PPM
The reason I asked is because I have an EzUHF for long range, and it is very flexible in accepting anything, even non-standard. I just received a Taranis, and within 5 minutes, using open TX, I had 12 channels working.
an example: fpvlab.com/forums/showthread.php?27271-PPM-frame-rate
I do agree it may be a non standard protocol, but as far as I am concerned, I don't care, as long as it works.
I guess it should be very easy to implement something "non-standard" in deviation as long as the user is aware it is "non-standard". So when you choose 12 or more channels, a simple warning that the protocol is no longer "standard" would do.
Is it possible to implement something like that?
I like my Devo12S, I like Deviation and I would like to see more and more features. I need more than 10 channels (that's why I bought the Devo12S in the first place) and maybe others are in the same position.
Last edit: 31 May 2014 11:18 by Pattaya01.
- sbstnp
31 May 2014 12:58 #23783
Replied by PhracturedBlue on topic PPM
Yes Taranis allows more than 10 channels on PPM. Deviation does too now
The max # of channels calculation is:
(PW-notch) / (center + delta + notch)
so default is 11.
increasing the PW will allow you to have more channels.
Note that you are limited to the maximum # of channels supported by the radio (currently 12 for all radios)
so default is 11.
- Pattaya01
- Pattaya01
01 Jun 2014 13:32 #23820
click on PPM and change the 'Frame Size' to 25000. That should allow you to fit 12 channels
Should have said:The max # of channels calculation is:
(Framesize-notch) / (center + delta + notch)
- Kdean
Time to create page: 0.981 seconds
