devo 12s just with the dsm2 availability
20 May 2014 19:06 #23416 by roger20000
devo 12s just with the dsm2 availability was created by roger20000
hi, is there any way i can get my devo 12s just to have the part that connects it with the spektrum dsm2. it's amazing how this works and i cant believe walkera don't put it in as standard unless there's some copyright issue. i dont like the devention interface and it does no favours to the ease of use but if i could just bind to a spektrum receiver i'd be happy.
21 May 2014 23:11 #23482 by Hexperience
Replied by Hexperience on topic devo 12s just with the dsm2 availability
It's the deviation software that allows you to bind to dsm2/X not hardware. There's no way to bind dsm to the stock walkera firmware.
22 May 2014 06:30 #23492 by cropduster
Replied by cropduster on topic devo 12s just with the dsm2 availability
Roger,
if you use the standard GUI and just play around a bit with the layout, you can make it look "nicer". There is also a layout/wallpaper out there, that takes the original icons from stock firmware for the standard GUI.
I changed the background bmp and played around with the colors, so now everything is dark blue-ish and now it looks even nicer than stock firmware.
Michael
16 May 2015 01:34 #32637 by ave1
Replied by ave1 on topic devo 12s just with the dsm2 availability
can I see your bmp and how you used it, please?
Time to create page: 0.368 seconds
