New installation
30 May 2014 18:09 - 30 May 2014 18:10 #23764 by Torch
New installation was created by Torch
First time trying Deviation. I have Devo 7E.
Do I install deviation-devo7e-v4.01.zip or the nightly builds listed below?
On nightly builds there are two Devo 7e zip files which do I used?
deviation-devo7e-v4.0.1-e2ae2cc.zip
deviation-emu_devo7e-v4.0.1-e2ae2cc.zip
What does the emu do?
Last edit: 30 May 2014 18:10 by Torch.
30 May 2014 18:39 #23765 by Fixy
Replied by Fixy on topic New installation
emu is an emulator to run on your computer.
You should install 4.0.1 first to see how things work and then why not a nightly if you need a particular feature.
31 May 2014 01:59 #23769 by Torch
Replied by Torch on topic New installation
Installed DfuSe Tool (latest version) and successful performed firmware update to Devo7E. So USB port, driver and USB cable is working on Windows 7 64 bit.
Shutdown and restart devo7e pressing ENT button nothing happens? It won't detect drive?
Do I have to upgrade different firmware (Devo 7 or 8) to destroy the existing setup on the Devo7e?
31 May 2014 02:54 #23770 by Torch
Never Mind Figure it out. Deviation installed.
31 May 2014 03:03 #23771 by Torch
How can I select other Models? For example model 1(v120) and model2 (QR Ladybird). Upon bootup the TX only boots to Model1?
31 May 2014 03:11 #23772 by WheresWaldo
Replied by WheresWaldo on topic New installation
Upon power on it will always try to load the last model loaded. The sequence is:
ENT >> Model menu >> ENT >> Model setup >> ENT >> Load... >> ENT >> Up | Down >> ENT
31 May 2014 04:12 - 31 May 2014 04:27 #23774 by Torch
Thanks now I mess up and v120d02 won't bind to devo 7E. I like to go back to my default Devo 7E firmware if possible. Will re-attempt Deviation next time.
However upgrading firmwware back to Walkera Devo7E when I power up it shows Throttle Stick and I can't do anything?
Last edit: 31 May 2014 04:27 by Torch.
03 Jun 2014 01:53 #23868 by charlottewindow099
Replied by charlottewindow099 on topic New installation
Same problem here :( :( :(
03 Jun 2014 17:24 #23880 by Torch
Evertime you upgrade Walkera Devo7E firmware, it goes back to stick mode 1. Therefore you reboot TX with throttle stick at midstick. This is why you are seeing this message. Press your right stick up way down and you will see the Devention software come up. Then change it back to stick mode 2.
It happen to me, now I don't panic no more and have gone back to Deviation V4 installation and is flying it for my V120,Ladybird and hope soon 130x.
Time to create page: 0.077 seconds
