Devo 10 settings
- lifeguard49uk
02 Jun 2014 18:25 #23856
by lifeguard49uk
Devo 10 settings was created by lifeguard49uk
Hi
I have bought a second Devo 10 to use with my Walkera 350 Pro - my question is - is there an easy way to transfer my model settings from old tx to new one?? Would be nice if I could connect them both together and exchange model settings.
- jesmail
02 Jun 2014 20:16 #23859
by jesmail
Replied by jesmail on topic Devo 10 settings
I assume you are using 4.01 standard.
Sure it is easy. Copy from the models directory to your pc, then copy them to the new Devo 10 models directory.
- lifeguard49uk
03 Jun 2014 17:49 #23882
by lifeguard49uk
Replied by lifeguard49uk on topic Devo 10 settings
Hi Jesmail
thanks for that. Old one is on standard issue for Walkera QR350 Pro but I upgraded the new one to 4.01.
Will give it a go - thanks again
Jack K
Jack K
- jesmail
03 Jun 2014 21:26 #23883
by jesmail
Since the old one is using stock firmware, the copy will not work. You would be better off to look in the models section and download one for your model.
Time to create page: 0.667 seconds
- Devo 10 settings
