100-150mv
- unclecrash
09 Jul 2014 17:03 #24506
Replied by PhracturedBlue on topic 100-150mv
should be fine. The FCC limits output power to 30dBm. None of the transmitters we have will put out anything over 22dBm. (There is a rule about derating power with higher gain antenna, but even here, it should be ok).
Note that these chips are very inefficient at 150mW. They will get warm and significantly increase battery usage. Unless you really need the range, I don't recommend using it.
Time to create page: 0.610 seconds
