100-150mv
08 Jul 2014 20:58 - 08 Jul 2014 22:42 #24474 by unclecrash
100-150mv was created by unclecrash
Wondering are we in the USA allowed to use the 150mv setting? Oh boy and now would like to know what the uw settings are for?
Last edit: 08 Jul 2014 22:42 by unclecrash. Reason: Just found uw
09 Jul 2014 17:03 #24506 by PhracturedBlue
Replied by PhracturedBlue on topic 100-150mv
should be fine. The FCC limits output power to 30dBm. None of the transmitters we have will put out anything over 22dBm. (There is a rule about derating power with higher gain antenna, but even here, it should be ok).
Note that these chips are very inefficient at 150mW. They will get warm and significantly increase battery usage. Unless you really need the range, I don't recommend using it.
09 Jul 2014 19:34 #24509 by unclecrash
Replied by unclecrash on topic 100-150mv
Thanks PB when I get ready I will use a cheap foamy and test it set lower like I have seen others do. The farthest I go is with my gliders.
Time to create page: 0.496 seconds
