3 extra modules in a devo 10 or 12s
- TomPeer
28 Jul 2014 19:50 #24873
by TomPeer
3 extra modules in a devo 10 or 12s was created by TomPeer
I would like to solder in al three modules in a devo 10 or 12s.
Ntf24l01, a7105 and cc2500.
Is it possible for 2 modules to share a connection to tms or tck?
Or should i use a switch. And if so should i switch the tms/tck or the 3.3v lead.
or both (2 poles).
Or... is it just not possible and should i forget it.
Thanks for the help.
or both (2 poles).
- aMax
28 Jul 2014 21:43 - 28 Jul 2014 22:30 #24875
by aMax
Replied by aMax on topic 3 extra modules in a devo 10 or 12s
It will be a good idea to leave VCC connected.
But you will have to pay attention for CSN, staying high (module not selected).
So a 2 pole switch is not enough, one 2x3 will pass the signal through and keep the other line with a pull up high.
It is not as simple as from a PPM Modul to an additional 2.4 module.
Just my two cents.
EDIT: Keep in mind, the software may not handle a double entry for A13 or A14 and you will have to edit the hardware.ini everytime or a - Module not found-
will appear.
Just my two cents.
will appear.
Last edit: 28 Jul 2014 22:30 by aMax.
- TomPeer
29 Jul 2014 07:22 - 29 Jul 2014 16:43 #24883
by TomPeer
Replied by TomPeer on topic 3 extra modules in a devo 10 or 12s
Thank you for this information.
One of the reasons i like deviation so much is that i simply can chose between models with different protocols. I don't want to compromise that. So i will leave it with 2 modules then.
Waiting for the multiprotocol module board.
Again thanks.
Again thanks.
Last edit: 29 Jul 2014 16:43 by TomPeer.
- SeByDocKy
29 Jul 2014 07:46 #24884
by SeByDocKy
The only way to have 3 RF chips (or 4) actually is via the Multimodule ....
Replied by SeByDocKy on topic 3 extra modules in a devo 10 or 12s
TomPeer wrote: Hello,
or both (2 poles).
Time to create page: 0.796 seconds
- 3 extra modules in a devo 10 or 12s
