Programming gyro V120D02S Devo 7E
30 Jul 2014 16:44 #24911 by saidem
Programming gyro V120D02S Devo 7E was created by saidem
I have receiver with Helico V120D02S RX2636H-D and Devo 8S. With this Devo Devention gyroscope moves the tail rotor and the swashplate. I upgraded to 4.0.1 Deviation with Devo 7E. The gyro moves the tail rotor, but not the swashplate. I think I misconfigured deviation, I went through mixers and I put on channel 7. Everything else works.
I'm a bit lost, could you help me please.
Thank you.
File Attachment:
File Name: model3.ini
File Size:8 KB
30 Jul 2014 17:28 - 30 Jul 2014 17:29 #24913 by sbstnp
Replied by sbstnp on topic Programming gyro V120D02S Devo 7E
You have a deadband curve on channel 7.
Keep template as Expo&DR and configure:
Pos 0 (High): curve=fixed, switch=none, scale=70, offset=0
Pos 1 (Mid): curve=fixed, switch=MIX1, scale=55, offset=0
Pos 2 (Low): curve=fixed, switch=MIX2, scale=25, offset=0
Change MIX1 and MIX2 with what switches you have available. You can even leave out the third position.
Gyro value needs translation to Deviation scale, like this:
dev_value = (manual_value + 100) /2
So for for gyro at 60 you have:
value = (60+100)/2 = 80
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Last edit: 30 Jul 2014 17:29 by sbstnp.
30 Jul 2014 19:36 #24918 by saidem
Replied by saidem on topic Programming gyro V120D02S Devo 7E
Hi
I return you the updated file. Tell me if it's OK, as Devo 7E has only 2 positions FMOD 0 and 1. In the template Expo & Dual Rate I have not found the Offset. I have attached the file for you to tell me if it is OK.
Thank you
File Attachment:
File Name: model3_2014-07-30.ini
File Size:8 KB
30 Jul 2014 20:24 #24920 by sbstnp
Yes looks ok, gyro should be active. keep in mind though this controls only the tail gyro, the swash gyro gains is controlled by the pots on the flightboard.
Devo 10 + 4in1
Spektrum Dx9
31 Jul 2014 10:10 #24937 by saidem
I tried with the settings you gave me, but it did not change anything. After searching a bit more, I saw that I had cut the throttle because I also installed the "sticky" throttle hold. You can see in Virt.4. So when I put the throttle it works. But in fact, I do not know why turning off the throttle influences the swashplate gyro. If you know why, I'm interested. I did not understand as "controlled by the pots on the flightboard".
Thanks.
Time to create page: 0.091 seconds
