- Devo 10 channel output channel assignments
- Ferdey
12 Aug 2014 09:32 #25170
by Ferdey
Devo 10 channel output channel assignments was created by Ferdey
I see when I change protocols that the channel assignments change under the mixer settings. I want to change the channel assignments separately to the protocol, is this possible to do?
For example, I have a Dominator 450L with a 3GX unit and Spektrum satellites. I am using DSMX/DSM2 to bind to the satellites but the 3GX requires certain channel mappings and unlike my Bavarian Demon the 3GX setup cannot re-assign channels.
Thanks,
Rob
Thanks,
Rob
12 Aug 2014 14:48 #25172
Replied by mwm on topic Devo 10 channel output channel assignments
Yes. You may need to use the advanced mixer gui. But in that, you can assign the source for each mixer on a channel to be any input you want.
- Ferdey
12 Aug 2014 19:13 #25180
by Ferdey
Replied by Ferdey on topic Devo 10 channel output channel assignments
Thanks for that. Do you know of any examples around here of doing that? I am totally new to deviation, that advanced mixer gui is very hard to understand
I've read the devo 10 doc but it doesn't go into detail on this...
- Ferdey
13 Aug 2014 08:46 #25184
by Ferdey
Found this, which greatly helped:
www.deviationtx.com/forum/how-to/1226-ho...s-on-custom-firmware
Time to create page: 0.218 seconds
