Devo 10 channel output channel assignments
12 Aug 2014 09:32 #25170 by Ferdey
I see when I change protocols that the channel assignments change under the mixer settings. I want to change the channel assignments separately to the protocol, is this possible to do?
For example, I have a Dominator 450L with a 3GX unit and Spektrum satellites. I am using DSMX/DSM2 to bind to the satellites but the 3GX requires certain channel mappings and unlike my Bavarian Demon the 3GX setup cannot re-assign channels.
Thanks,
Rob
12 Aug 2014 14:48 #25172 by mwm
Yes. You may need to use the advanced mixer gui. But in that, you can assign the source for each mixer on a channel to be any input you want.
12 Aug 2014 19:13 #25180 by Ferdey
Replied by Ferdey on topic Devo 10 channel output channel assignments
Thanks for that. Do you know of any examples around here of doing that? I am totally new to deviation, that advanced mixer gui is very hard to understand :S
I've read the devo 10 doc but it doesn't go into detail on this...
13 Aug 2014 08:46 #25184 by Ferdey
Time to create page: 0.113 seconds
