- Assign a channel to either switch on 7e?
- bmw111
21 Aug 2014 20:06 #25336
by bmw111
Assign a channel to either switch on 7e? was created by bmw111
Hi, new 7e owner, flashed Deviation this morning, read/searched through the threads, but can't figure out how to simply assign the FMOD or Hold switches to a channel. (I usually fly with a Futaba 14SG, but got the 7e for my recently renewed interest in small quads.) I know the switches are active, I can see that in the Stick Input screen -- but they do not show movement on any of the channels in the Channel Output screen.
This is something that is second nature to me using Futaba gear. I'm frustrated that something usually so simple seems to be complicated in Deviation. What am I missing? Thanks to all...
- Deal57
21 Aug 2014 21:14 - 21 Aug 2014 21:16 #25337
by Deal57
Replied by Deal57 on topic Assign a channel to either switch on 7e?
Its not exactly intuitive, but you'll get it if you go through the model.ini files. Here is a clip I use with my V272 to allow me to get into Flip mode on the V272:
[channel6]
template=simple
[mixer]
src=FMODE1
dest=Ch6
curvetype=expo
points=0,0
I also have three rates on the Aileron (roll) channel based on the position of the right three-way switch (SW B -- the left side 3-way is SW A):
[channel1]
reverse=1
template=expo_dr
[mixer]
src=AIL
dest=Ch1
scalar=60
curvetype=expo
points=-10,-10
[mixer]
src=AIL
dest=Ch1
switch=SW B1
scalar=80
curvetype=expo
points=-10,-10
[mixer]
src=AIL
dest=Ch1
switch=SW B2
curvetype=expo
points=-10,-10
Download all the model.ini files you can find...there are a lot of ways to use them.
[channel6]
template=simple
[mixer]
src=FMODE1
dest=Ch6
curvetype=expo
points=0,0
[channel1]
reverse=1
template=expo_dr
[mixer]
src=AIL
dest=Ch1
scalar=60
curvetype=expo
points=-10,-10
[mixer]
src=AIL
dest=Ch1
switch=SW B1
scalar=80
curvetype=expo
points=-10,-10
[mixer]
src=AIL
dest=Ch1
switch=SW B2
curvetype=expo
points=-10,-10
Last edit: 21 Aug 2014 21:16 by Deal57. Reason: Oops.
- TomPeer
21 Aug 2014 21:17 #25338
by TomPeer
Replied by TomPeer on topic Assign a channel to either switch on 7e?
Hello
If you want to assign a hold switch; go to mixer, then clic on THR. there you find safety, here you can choose a switch you want.
For the other switches:
go to mixer. Clic on the button next to the channel of your choise. there you can choose None, Simpel, Expo&DR, Complex and Cyclic.
You need to choose Expo&DR or Complex, If you toggle down you wiil find Switch, there you can assign a switch you want.
Good Luck
Good Luck
- walshy
21 Aug 2014 21:50 #25339
by walshy
Replied by walshy on topic Assign a channel to either switch on 7e?
(in advanced mixer guide)
1.go to model menu
2.click on mixer
3.click on throttle channel
4.choose 2 mixers (these 2 mixers will be your normal and idle)
5.put your 2 different throttle curves in
6.now it says page 1 and 2 click on 2
7.now where it says (switch) change it to fmode1
do the same to pitch channel and thats your fmode done.
now for throttle hold
1.go to model menu
2.go to mixer
3.click on (1-thr)
4.click on safety and change it to throttle hold1
5.click on (safe val)and change it to -100
hope this helps mate.I no what its like trying to learn this stuff.I got into it about 6 months ago and still dont understand everything
1.go to model menu
2.click on mixer
1.go to model menu
2.go to mixer
3.click on (1-thr)
- bmw111
22 Aug 2014 03:14 #25344
by bmw111
Replied by bmw111 on topic Assign a channel to either switch on 7e?
Thanks, all. This has given me a solid point to work from.
Cheers.
Cheers.
Time to create page: 0.378 seconds
