Antenna range
06 Sep 2014 13:52 - 06 Sep 2014 13:53 #25520 by TomPeer
Antenna range was created by TomPeer
If i keep the antenna's of the extra modules in the casing of the transmitter, would that effect the range much, in comparison against external antenna's?
Thanks,
Tom
Last edit: 06 Sep 2014 13:53 by TomPeer.
06 Sep 2014 15:10 - 06 Sep 2014 15:11 #25521 by aMax
Replied by aMax on topic Antenna range
If mouted into the top of the case and kept horizontal, never mind.
Depends on the antenna and the right length. A plastic cover is anyway
round the wire, even at an external.
This one made no difference to an external at another tx.
www.bilder-hosting.info/viewer.php?id=arx1399946310k.jpg
Last edit: 06 Sep 2014 15:11 by aMax.
06 Sep 2014 15:41 - 06 Sep 2014 15:41 #25522 by TomPeer
Replied by TomPeer on topic Antenna range
Thank you.
What about this one.
www.banggood.com/A7105-Wireless-RF-2_4GH...Module-p-909404.html
Would it matter to change the smal wire for a longer one, for example from the original 911 module.
Tom
Last edit: 06 Sep 2014 15:41 by TomPeer.
06 Sep 2014 16:44 #25523 by Arakon
Replied by Arakon on topic Antenna range
2.4ghz doesn't work that way. A longer wire will actually reduce your range. There's a reason why it's exactly that long.
06 Sep 2014 17:54 - 06 Sep 2014 17:59 #25527 by aMax
I have exact this module and you will not fly as far as it is possible with that module, trust me.
Nearly lost a V911 in nastier wind and it was with 3mW still steerable within
200m but would not come back. :whistle:
This setup was for flying into the garden...ONLY...I supposed ...
Last edit: 06 Sep 2014 17:59 by aMax.
06 Sep 2014 21:38 #25532 by TomPeer
Thanks for this information.
I'll keep it al original.
Time to create page: 0.239 seconds
