- adjusting esc end points w/deviation PLEASE HELP
- Tkaiser
30 Nov 2014 21:02 - 30 Nov 2014 21:40 #26693
by Tkaiser
adjusting esc end points w/deviation PLEASE HELP was created by Tkaiser
Hi there im having an issue with setting my end points on my castle creations 130amp esc the issue isnt with the esc its with the -100 to +100 on the throttle scale the end points set fine with the esc but when i spool up it seems to be at 50% throttle at quarter stick and 100% at half stick any help would be greatly appreciated P.S im using a devo 8s the latest deviation release
Last edit: 30 Nov 2014 21:40 by Tkaiser.
- Thomas.Heiss
30 Nov 2014 21:38 #26694
by Thomas.Heiss
Replied by Thomas.Heiss on topic adjusting esc end points w/deviation PLEASE HELP
Have you finished throttle calibration with up/down throttle stick in the CC programming menu?
- Tkaiser
30 Nov 2014 21:45 #26695
by Tkaiser
Replied by Tkaiser on topic adjusting esc end points w/deviation PLEASE HELP
yes the esc is all programed and as far as the throttle end point calibration it seems to be set, high stick is at +96% and low stick is at -88% in travel adjust menue
- kreidler
03 Dec 2014 20:16 #26748
by kreidler
Replied by kreidler on topic adjusting esc end points w/deviation PLEASE HELP
What does stick input and channel output for throttle on the Devo show? Also +- 100?
- djsmeegy
17 Jun 2015 04:49 - 18 Jun 2015 07:37 #34204
by djsmeegy
Replied by djsmeegy on topic adjusting esc end points w/deviation PLEASE HELP
Hi guys,
I have castle creations edge 50A on my helicopter T-rex 450L. I want to calibrate THR scale of the TX. I have Devo 10, deviation 4.0.1.
I have thr setting w/ 5 mixes:
will use goveronor so three flat curves:
(1)FMODE0 - 30,30,30,30,30 and
(2)FMODE1 - 75,75,75,75,75, and
(3)FMODE2 - 100,100,100,100,100
(4) switch rud d/r 0,50,100 (for callibration) and
(5) switch Gear - -100,-100,-100,-100,-100
By following CC manual for thr callibration, I tried to set hi & low points - reprogram tx curve (4) 50, 50, 50, and then increased to 100 all values, but I think it was wrong.
Aslo I think I have wrong settings in my tx, bcoz I have scale 100 and thr reaches -100/+100 so I think I have to recalculate all curves to desired range -100/+100 not only 0/100, am I right?
Or what can I do to have proper setup to be able to learn esc my throttle hi&lo values, disarm ESC and run my helicopter w cc edge?
Edit: I'll post the model.ini file later.
Edit2: I found out, I will have to use this formula from 0to100 to -100to+100: (0 to 100 value)-50 x 2
Then I hope it will be OK.
Edit3: I uploaded my model.ini file and also I updated the values there, so now I will try to test it
PS: I added mix6 for the autotration and as well the gyro gain. Also I modified the pitch curves,
Last edit: 18 Jun 2015 07:37 by djsmeegy.
- Thomas.Heiss
17 Jun 2015 10:37 - 17 Jun 2015 10:40 #34211
by Thomas.Heiss
If you have e.g 73% throttle on 0-100 it is on -100-+100 scale: 46
Alternative formula: 73 * 2 - 100
UPDATE: Yes your formula looks to be OK too. Sorry, but I made a calculation error myself before when testing.
Unfortunately I am not familiar with CC calibration.
But wouldn't you have to set throttle curve from -100 to +100 for proper low/high learnings first?
Ahd then recalibrate 30/75/100 (0..100) (Spektrum) settings to the proper -100-+100 range values afterwards?
Last edit: 17 Jun 2015 10:40 by Thomas.Heiss.
- djsmeegy
18 Jun 2015 07:37 #34264
by djsmeegy
I finalized the range learning procedure for CC Edge and now ESC recognises my tx range. I did the procedure following by CC guide - set both ATV close to 50 (in my case scale + and scale -) then put thr to hi and start learning procedure. When ESC recognise the hi value, inrease ATV for 2 points, the same story for low.
The interesting result indeed is I have scale + 97(hi) and scale - 144 (low).
Hope it will be OK, but seems to be
usually I had +/-100 scale.
Time to create page: 0.122 seconds
