adjusting esc end points w/deviation PLEASE HELP
30 Nov 2014 21:02 - 30 Nov 2014 21:40 #26693 by Tkaiser
Hi there im having an issue with setting my end points on my castle creations 130amp esc the issue isnt with the esc its with the -100 to +100 on the throttle scale the end points set fine with the esc but when i spool up it seems to be at 50% throttle at quarter stick and 100% at half stick any help would be greatly appreciated P.S im using a devo 8s the latest deviation release
Last edit: 30 Nov 2014 21:40 by Tkaiser.
30 Nov 2014 21:38 #26694 by Thomas.Heiss
Replied by Thomas.Heiss on topic adjusting esc end points w/deviation PLEASE HELP
Have you finished throttle calibration with up/down throttle stick in the CC programming menu?
30 Nov 2014 21:45 #26695 by Tkaiser
yes the esc is all programed and as far as the throttle end point calibration it seems to be set, high stick is at +96% and low stick is at -88% in travel adjust menue
03 Dec 2014 20:16 #26748 by kreidler
What does stick input and channel output for throttle on the Devo show? Also +- 100?
17 Jun 2015 04:49 - 18 Jun 2015 07:37 #34204 by djsmeegy
Hi guys,
I have castle creations edge 50A on my helicopter T-rex 450L. I want to calibrate THR scale of the TX. I have Devo 10, deviation 4.0.1.
I have thr setting w/ 5 mixes:
will use goveronor so three flat curves:
(1)FMODE0 - 30,30,30,30,30 and
(2)FMODE1 - 75,75,75,75,75, and
(3)FMODE2 - 100,100,100,100,100
(4) switch rud d/r 0,50,100 (for callibration) and
(5) switch Gear - -100,-100,-100,-100,-100
By following CC manual for thr callibration, I tried to set hi & low points - reprogram tx curve (4) 50, 50, 50, and then increased to 100 all values, but I think it was wrong.
Aslo I think I have wrong settings in my tx, bcoz I have scale 100 and thr reaches -100/+100 so I think I have to recalculate all curves to desired range -100/+100 not only 0/100, am I right?
Or what can I do to have proper setup to be able to learn esc my throttle hi&lo values, disarm ESC and run my helicopter w cc edge?
Edit: I'll post the model.ini file later.
Edit2: I found out, I will have to use this formula from 0to100 to -100to+100: (0 to 100 value)-50 x 2 :) Then I hope it will be OK.
Edit3: I uploaded my model.ini file and also I updated the values there, so now I will try to test it :) PS: I added mix6 for the autotration and as well the gyro gain. Also I modified the pitch curves,
Last edit: 18 Jun 2015 07:37 by djsmeegy.
17 Jun 2015 10:37 - 17 Jun 2015 10:40 #34211 by Thomas.Heiss
If you have e.g 73% throttle on 0-100 it is on -100-+100 scale: 46
Alternative formula: 73 * 2 - 100
UPDATE: Yes your formula looks to be OK too. Sorry, but I made a calculation error myself before when testing.
Unfortunately I am not familiar with CC calibration.
But wouldn't you have to set throttle curve from -100 to +100 for proper low/high learnings first?
Ahd then recalibrate 30/75/100 (0..100) (Spektrum) settings to the proper -100-+100 range values afterwards?
Last edit: 17 Jun 2015 10:40 by Thomas.Heiss.
18 Jun 2015 07:37 #34264 by djsmeegy
I finalized the range learning procedure for CC Edge and now ESC recognises my tx range. I did the procedure following by CC guide - set both ATV close to 50 (in my case scale + and scale -) then put thr to hi and start learning procedure. When ESC recognise the hi value, inrease ATV for 2 points, the same story for low.
The interesting result indeed is I have scale + 97(hi) and scale - 144 (low).
Hope it will be OK, but seems to be :) usually I had +/-100 scale.
Time to create page: 0.113 seconds
