USB Problem Devo 10
05 Feb 2017 00:54 #58756 by calico
Replied by calico on topic USB Problem Devo 10
can anyone help ?
05 Feb 2017 12:49 #58770 by FDR
Replied by FDR on topic USB Problem Devo 10
According to this wiki page:
www.deviationtx.com/wiki/hardware/devo10
the BOOT0 pin is on CON2...
09 Feb 2017 11:13 #58972 by calico
where in the world con2 is ?
google doesn't help....
can't find "con2" text on the board
connector 2 ? where ?
09 Feb 2017 11:33 - 09 Feb 2017 11:33 #58973 by FDR
A few minutes search in the datasheet and the downloadable tx images revealed, that the BOOT0 pin is the pin 94, which leads to the small two pole unsoldered connector place on the right of the processor, just above the NRESET+TMS+etc connector.
Last edit: 09 Feb 2017 11:33 by FDR.
10 Feb 2017 07:47 #59021 by calico
thank you again
28 Jan 2018 05:08 - 28 Jan 2018 05:10 #67226 by Seven5555
Replied by Seven5555 on topic USB Problem Devo 10
I just wanted to say thank you. I used Dfuse 3.05 demo and my Devo 10 was stuck it in dfu mode and unresponsive..
So, I used DfuSe v2.1 to load the stock FW 0.8B but didnt get it completely resolved until I loaded the library dfu file (in the FW 8.B zip) using the library tab in the tool. Then I was able to push the Leave DFU mode button and it worked. Maybe that might help someone using windows 8.1 also.
Last edit: 28 Jan 2018 05:10 by Seven5555.
Time to create page: 0.507 seconds
