EN 300 328 V1.8.1
- deniss
24 Dec 2014 12:52 #27198
by deniss
EN 300 328 V1.8.1 was created by deniss
Hi guys,
can you tell me if your radio software reply to the new EU rule EN 300 328 V1.8.1 ?
thanks !
denis
thanks !
denis
- aMax
24 Dec 2014 14:26 - 24 Dec 2014 14:30 #27199
by aMax
e.g. Walkera,Spektrum, FrSky, ..etc
E.G.... Graupner (Hott):
"Est-ce que les consommateurs peuvent utiliser des émetteurs ou des récepteurs sans mise à jour à partir du 2015? On peut utiliser des émetteurs et des récepteurs à l’ancienne et à la nouvelle version du logiciel. "
"Dürfen nicht upgedatete Sender/Empfänger vom Endkunden ab 2015 verwendet werden? Verwendet werden dürfen sowohl Sender/Empfänger mit altem als auch mit neuem Softwarestand. "
Their english site displays nothing about that....
Replied by aMax on topic EN 300 328 V1.8.1
You better ask this the main hardware and protocol producer.deniss wrote: Hi guys,
thanks !
denis
Last edit: 24 Dec 2014 14:30 by aMax.
- linux-user
02 Jan 2015 00:05 - 02 Jan 2015 17:41 #27404
by linux-user
Replied by linux-user on topic EN 300 328 V1.8.1
With regard to EN 300 328 Devo and DSM2 are non hopping DSSS Systems.
So the requirements are different than for the FHSS Systems like FrSky, Futaba T-FHSS, FASSTest etc.
Most discussed Limits of EN300328 V1.8.1 for DEVO and DSM2/DSMX:
1. Nobody has ever made any compliance tests with deviation, so its usage is your own resposibility.
2. Deviation tries to behave as close as possible to the original OEM protocol, so with regard to compliance it should be similar - at least with devo protocol.
3. Sadly Walkera has not published any compliance tests in accordance to EN300328 which would allow 100mW TX-Power in Europe,
The only test I found in German forum is in regard to EN300440 which allows 10mW.
4. If we want to use devo with 100mW in Europe, this leaves us to guessing by reference to the FCC measurements.
You can search transition.fcc.gov/oet/ea/fccid/ and enter the FCC-ID:
i.e. for Devo10: S29 DEVO-10
There you can find:
Question to the HF-Gurus
Which one is more restrictive?
| TX-Power: | <= 20dBm (=100mW) E.I.R.P |
| Power Spectral Density: | <= 10mW / 1MHz (Part 4.3.2.2.) |
There you can find:
| Devo-10 | FCC Test result | Limit for EN 300328 V1.8.1 |
| max TX-Power: | 19.31 dBm (EIRP) (0.085W) | 20 dBm (=100mW) E.I.R.P. |
| Power Spectral Density: | 6.03 dBm/3KHz | 10 dBm / 1MHz |
| FCC Part 15.247: | EN300328 V1.8.1: |
| Power Spectral Density < 8db / 3kHz | Power Spectral Density < 10dBm / 1MHz |
Last edit: 02 Jan 2015 17:41 by linux-user.
Time to create page: 0.193 seconds
- EN 300 328 V1.8.1
