Buzzing noise from Devo7e after deviation hacking
18 Jan 2015 11:32 #27793 by lucas1414
Hello everybody,
I've just installed Deviation Tx on my devo 7e and it looks amazing, even though i'm only using the standard parameters to fly my Super CP. I really don't understand yet the way the mixers works in the advance mode... Thanks to the develloper(s)!!!
Anyway, since I installed deviation and right after the first reboot, my Transmitter started to buzz like a electronic component was under pressure. Some times it stops... I first thought the buzzer was making this noise so I went the the parameters and change the volume level and it worked, but only for a while. I don't think it has anything to do with the buzzer cause any other change in any parameters could make it stop aswell...
Does anyone have the same problem?
18 Jan 2015 13:09 #27796 by aMax
Any module?
Which firmware version?
Please test the nightly from 01 Aug 2014 and report.
18 Jan 2015 13:11 #27797 by lucas1414
No not any hardware modif to the transmitter I'm running on Deviation 4.0.1...
Ok I will try that!
18 Jan 2015 13:23 #27798 by aMax
Ok.
I had this too after installing 4.01. After the range mod it was less but still there. ( corresponding to the selected output power)
Therefore I shut off the speaker and used the vibration alarm.
But after this nightly my 7e has no issue with that anymore.
18 Jan 2015 13:32 #27799 by lucas1414
Ok yeah it looks fine now, i'm gonna try it for a bit longer but looks like the update has solved it! Thanks you aMax!
As you speak about the long range mod have you experience any troubles with it? I've read on other posts that it could over stress the 3.3v regulator...
thank you anyway!
18 Jan 2015 13:52 - 18 Jan 2015 13:55 #27802 by aMax
Not the range mod, the old wiring of the A7105-D03....at least the combination.
Last edit: 18 Jan 2015 13:55 by aMax.
