RX-2702V Gyro Problem
- saad khan
21 Jan 2015 11:35 #27919
by saad khan
RX-2702V Gyro Problem was created by saad khan
Im rebuilding my v450d01 and just went through all the mechanical/swash/RX setup. I just checked my gyro direction and everything is good except the aileron direction. I tried reversing the setting using the little switch on the RX but it does not change anything. When I tilt the heli Left the swash plate tilts Left (not good....). Any ideas? The rudder and Elevator reverse switches seem to work when I change them.
- Zaphod
25 Jan 2015 11:55 #28012
by Zaphod
Replied by Zaphod on topic RX-2702V Gyro Problem
If you reverse it in the tx does that resolve the issue?
I never had much luck with my RX2702V.Upgraded to the RX2703V-D and its perfect.
- Zaphod
25 Jan 2015 11:58 #28013
by Zaphod
Might be worth watching this too -http://youtu.be/BUnak6YDdGc
Time to create page: 0.111 seconds
- RX-2702V Gyro Problem
