Devo 8S/Blade heli's
28 Jan 2015 19:59 #28180 by Barclay
Devo 8S/Blade heli's was created by Barclay
Hi, I have a DEVO 8S and have seen the video of how to solder the 7105 module to it so I can fly a V911. Can I fly a Blade without any soldering? In the Deviation supported model list it shows the same module for the Blade as it does for the Walkera (CYRF9636). In other words, if I buy a Blade 450X can I use my 8S without modification as I do with my V120D02S? Any special procedure? Thanks, Barclay.
28 Jan 2015 20:14 #28182 by Arakon
Replied by Arakon on topic Devo 8S/Blade heli's
You still need to install Deviation to it for that to work. But no physical modification is needed.
Time to create page: 0.040 seconds
